Can Output to AIM Dashes?
Support for EMU BLACK device
WCCoffey
Post by WCCoffey » Sun Dec 11, 2016 1:09 am
Does anyone know how to make the EMU Black communicate to an AiM MXG Dash?
Re: Can Output to AIM Dashes?
Post by Karel » Sun Dec 11, 2016 8:54 am
WCCoffey wrote:Does anyone know how to make the EMU Black communicate to an AiM MXG Dash?
I made it trough serial line ... works fine
MrBmw
Post by MrBmw » Sun Dec 11, 2016 10:41 am
Is it possible to connect both an AIM strada dash and the DL1 logger to the EMU Black?
/A
Post by Jadzwin » Mon Dec 12, 2016 12:13 am
Yes, via CAN. EMU BLACK supports many data streams (eg. Pectel Omega) that are supported by AIM
WCCoffey
Post by WCCoffey » Mon Dec 12, 2016 2:43 am
Ah, Perfect.
Thanks!
pault
Post by pault » Fri Feb 03, 2017 1:54 am
Can anyone elaborate more on this? Connecting a MXS Strada to an EMU Black and had a quick go tonight.Has someone succesfully done this via CAN? What do you set the dash to in Black software as AIM is not listed?
Cheers
Paul
WCCoffey
Post by WCCoffey » Sun Apr 16, 2017 5:06 am
pault wrote:Can anyone elaborate more on this? Connecting a MXS Strada to an EMU Black and had a quick go tonight.Has someone succesfully done this via CAN? What do you set the dash to in Black software as AIM is not listed?
Cheers
Paul
Open EMU Black Software
Go to "Can, Serial" and then "CAN"
Check the box "Send EMU Stream over CAN"
Go to the final box "CAN-Bus Dashboard"
I used "Pectel SQ6"
Then when you go into the AiM software and when you select the ECU datastream select "Pectel SQ6".
You will have proper communication.
What I haven't found is how to stream the WideBand to the dash. It might be possible with using different CAN Dashboard programming? or is this not possible at all? unsure.....
Gellersson
Post by Gellersson » Sun Apr 23, 2017 8:40 pm
if you have the AIM MXG, MXL2 system you can make your own can adress for the EMU data stream and get all the info the EMU sends out
Use the Custom Can in the racestudion 3 and put in what you want for Can 1 or can 2 also you can add RX and TX info
regards
Christer Gellerstedt
WCCoffey
Post by WCCoffey » Sun Jul 02, 2017 12:10 am
That would be awesome, but I am not familiar with can addresses and protocols.. I know enough to know that if you get it wrong, it messes everything up.
