N2O. & Water Meth control
Dear Sirs . How many stages of N2O can the Black ECU support?? Dry or wet N2O ?? Can the Black ECU control water Meth injection . In launch control can you have a different RPM limiter ?? For click banging a Turbo vechivle . Then have a higher RPM limiter once launch control is released . As when using a Trans Brake . I have plans to use a Black ECU on my 1997 Ford F150 4.2L V6 . Eaton M80 screw blower . Burning E85 . Would like to run Water Meth on this set up also .Highly interested in attending you trainig class in the USA . Possible 2018 too close to Sema this year $$ prohibitive in 2017. Terry
