I have a problem that i don't know what to do whit,
my timing whit timing light is way off ,if i look the timing in emu software on 30 degrees to get it to run,
timing light show 10 degrees,and trigger angle is 30 that is the lowest software allow me to,i tryed to make adjustments on other things,like first trigger tooth
output offset but that even make it bader,engine is a Subaru ej20g whit 36-2-2-2 trigger wheel,
i know i must be doing something wrong in settings,but don't know what
Base timing not correct !
Re: Base timing not correct !
you need to change the first trigger tooth and maybe start the ignition sequence from the next cylinder.... ie instead of 1342 start from 3421... i dont know your firing order but you get the idea!
