DBW and Vanos s54
Support for EMU BLACK device
driftkids
DBW and Vanos s54
Post by driftkids » Sat Jul 01, 2017 12:45 pm
What outputs are recommended to use for the 4x vanos soleionds on a S54, and what outputs can drive the DBW throttle ?
Re: DBW and Vanos s54
Post by Karel » Sun Jul 02, 2017 5:10 pm
driftkids wrote:What outputs are recommended to use for the 4x vanos soleionds on a S54, and what outputs can drive the DBW throttle ?
For Vanos use the aux outputs including flyback diodes, but you still need to switch polarity on S54 engine actuator for Vanos.
S54 does not have classic DBW, but has some high current motor for ITB, and EMU does not switch so high current, so you cant use it directly on EMU.
driftkids
Post by driftkids » Mon Jul 03, 2017 12:26 am
well, i have just been told by my dealer that the emu black can drive s54 throttle. is this not correct?
gregpe
Post by gregpe » Sun Jul 09, 2017 1:09 pm
S54 need an external driver for throttle due to high current. H bridges can drive vanos directly - there will be no needs for removing diodes from the unit.
