Bmw m62b44 turbo trigger
pepifebles
Hi guys, I have ignition problem with my m62b44 v8 turbo drift car. Only runs 4 or 5 cylinders. I check wiring, fitting order etc but think that my trigger setting (trigger angle) can be the problem.
Any help?
Any help?
The fun starts now
Re: Bmw m62b44 turbo trigger
i dont think...... trigger can make you run on 5 cylinders if you have them paired .....
Ignition firing order is 1-5-4-8-6-3-7-2 (except S65 = 1-5-4-8-7-2-6-3).
Bank-1 is the passenger side (cylinders 1 through 4), bank-2 is the driver side (cylinders 5 through 8).
pepifebles
I upload my trigger settings
The fun starts now
pepifebles
Log. My coils 2 and 8 dont runs.
- mirar 2.emulog
- (135.91KiB)Downloaded 107 times
The fun starts now
pepifebles
Cylinder 1 its passenger side near to front of car. Ok?Karel wrote:i dont think...... trigger can make you run on 5 cylinders if you have them paired .....
The fun starts now
if you sit inside, you have first cylinder on all front and right
http://www.fixya.com/fullimage.html?src ... 71923f.gif
pepifebles
I dont know where is the problem. Initially cylinders 2 and 8 not works. Wiring, coils, sparks checked. With strobe light, ignition timing its completely wrong, OT marks dont match.
Dont use Cam sensor
Dont use Cam sensor
- arranque y ralentí.emulog
- (68.48KiB)Downloaded 107 times
- V8 TURBO BASE BY JFG.emu
- (101.85KiB)Downloaded 125 times
- scope_201778_1831.emuscp
- Scope
- (332Bytes)Downloaded 116 times
The fun starts now
Why do you fire order 1234 1234 ?
i use it normal 1342 1342
in my experience the trigger works on cca 5tooth and 50degree , but i cant tell you exactly, because my work notebook is in the shop
pepifebles
My coils wiring 1-6, 2-8, 3-5, 4-7. Y tried your order ignition event and engine dont start
The fun starts now
pepifebles
Could it be that problem will be rising trigger edge instead falling trigger edge?
M60 crank wheel its in front of engine but my M62 its in the back of engine.
The fun starts now
pepifebles
When lock angle At 10º Strobe light read 14º and emu trigger angle dont change
The fun starts now
connect>
IGN1 1+6
IGN2 2+8
IGN3 3+5
IGN4 4+7
set
firing order 13421342
set
first trigger tooth to 5 and offset cca 50degree
then try to adjust it with timing lamp, large steps with tooth count and small with the angle
the same pairing and order with the injection just use only one times 1342 and set "squirt twice per cycle"
finish
if you are then not succesfull, you are doing something very wrong
IGN1 1+6
IGN2 2+8
IGN3 3+5
IGN4 4+7
set
set
finish
pepifebles
Thanks karel. My actual wiring its as you say. Tomorrow will prove your advises.
The fun starts now
pepifebles
What do you mean offset cca?Karel wrote:connect>
IGN1 1+6
IGN2 2+8
IGN3 3+5
IGN4 4+7
set
set
finish
Small steps with trigger angle or offset cca?
The fun starts now
I looked in my setup..... first trigger 1 , trigger angle 58
But on other engine with other sensor first trigger 6 and angle 51
so try what will start your engine and then finetune it with timimng lamp
pepifebles
This is the problem. In my old m60 first trigger is 3 and angle 49. There is a difference, m60 cranks sensor its in front of Engine in a small pulley, and in my actual m62 crank sensor its in the back of Engine, just in a gearbox Window.
Now the problem is too gap between timing marks (Engine cover and crank mark) and when I change angle value or trigger only get down the gap a little. Engine is completely out of time
The fun starts now
pepifebles
Solved. Thanks Karel.
Yesterday changed ignition event order but forget change injection events.
Now begin to tune.
Thanks.
Now begin to tune.
Thanks.
The fun starts now
Nice to hear you are succesfull now. Because it is basicly very simple engine.
pepifebles
Hi newly, Today begin to map but don't know if trigger its completely correct or there is another error. At idle without boost, engine revs up fine, but running and boost increase, feels like ignition cut and don't increase revs with too many explosions. I try change dwell time and get a little improve but its a disaster. Log, ignition, fuel, boost it seems correct, but something causes this explosions and the car don't run.
Any advise?
Any advise?
- Mapa 1 bueno.emu
- (101.84KiB)Downloaded 111 times
- ultimo.emulog
- (139.25KiB)Downloaded 114 times
The fun starts now
If it does iproove with the DWELL, so it must be coil/spark related.
What is you spark GAP ? Do you use this shitty two end electrodes ?
Startd with gap arround 0,5-0,7mm this should work fine
Looking into your log.... set the DWELL to 5ms at 12-14Volts, use single tip plugs and gap them to 0,6mm
should be huge iproovment.
