Dirty tune
pepifebles
Dirty tune
Post by pepifebles » Sat Sep 02, 2017 10:01 pm
Hi guys, recently have tuned bmw v8 turbo drift car. Engine runs fine, very fast, smooth iddle, spool fast, very angry athigh rpm, etc... The problem its that all its ok like stock car, not seem like race engine, its boring :( I need any flame between gears, or bangs. What can I do with tune to get something funny?
The fun starts now
Re: Dirty tune
Post by Karel » Sun Sep 03, 2017 1:27 pm
Everything "FUNNY" will make your engine sick. All the bangs may destroy your valves, manifold, turbo, o2 sensor etc..........
Re: Dirty tune
Post by RHD » Sun Sep 03, 2017 2:36 pm
you can turn off the over run fuel cut and bump all the VE table right up high in the over-run area, That makes nice big harmless flames out the exhaust on decel and gear changes etc
pepifebles
Re: Dirty tune
Post by pepifebles » Mon Sep 04, 2017 8:57 am
I know it, thanks for advise, but dont want something very agressive or exageerated, only a few funny sound or flames
The fun starts now
pepifebles
Re: Dirty tune
Post by pepifebles » Mon Sep 04, 2017 8:59 am
Thanks mate. Will try this changes. Thanks
The fun starts now
gnutz2
Re: Dirty tune
Post by gnutz2 » Mon Sep 04, 2017 2:35 pm
Put negative ignition numbers in the far left load column, and leave fuel on.
pepifebles
Re: Dirty tune
Post by pepifebles » Sun Oct 15, 2017 7:36 pm
Something like this? Dont get nothing :cry:
The fun starts now
Re: Dirty tune
Post by Karel » Mon Oct 16, 2017 10:52 am
Overrun fuel cut ... hmm i will better say decel fuel cut
Set
Fuel cut resume below RPM 6900RPM
Fuel cut above RPM to 7000RPM
This will not cut fuel under 7000RPM even on deceleration. But all the feul need also air to be able to burn. So if you TP is fully closed, you will probably have just very small amount of air.
If youwill make some stupidy funny noises, you can even on N/A use something like ALS. This function will still work the same way, just the bengs will useless, because there is no turbo to spin, so just for fun.
Schlander
Re: Dirty tune
Post by Schlander » Tue Nov 07, 2017 11:13 pm
Set
I'm listening? :lol:
Please explain, just for the fun :roll:
