EMU SOFTWARE 1.102 EXP 1
Get information about latest versions of software
Post by Jadzwin » Wed Feb 11, 2015 8:47 pm
Hi there!
There is a new software 1.102
This client software is compiled with the latest Visual studio and wxWidgets library.
There should be no UI flicker :) and some UI behavior is improved.
Looking for your suggestions...
Wuniek
Re: EMU SOFTWARE 1.102 EXP 1
Post by Wuniek » Wed Feb 11, 2015 9:44 pm
Unfortunately, this version is not stable on windows 8 Intel driver crashes , with 1.1 does not have this problem
Post by Jadzwin » Wed Feb 11, 2015 9:57 pm
Crashes instantly after start up ?
I hate intel drivers...
Wuniek
Post by Wuniek » Wed Feb 11, 2015 10:06 pm
Jadzwin wrote:Crashes instantly after start up ?
ok now i know what happen, in older version when you close app was popup with info do you want close xxx windows
from my observation app crash if number of windows was more than 120, now i clean up one dashboard and application start fine without error but limit dropped for me to about 110 windows
in attachment desktop template that works on 1.1 and crashes on 1.102
PS. The extension emulayout is not allowed.
dashboard.emu
(11.38KiB)Downloaded 190 times
Post by Jadzwin » Wed Feb 11, 2015 10:15 pm
The driver should never crash :)
We need to investigate this.
Wuniek
Post by Wuniek » Wed Feb 11, 2015 10:27 pm
Jadzwin wrote:The driver should never crash :)
before you put too much effort on this lets wait and see if someone else have same problem, because my laptop has few restrictions i cannot overlap:
- corporate windows 8 with company update policy
- old version of intel driver ( i cannot install nothing never)
- 120+ windows is a lot of unnecessary crap
astra vxr
Post by astra vxr » Wed Feb 11, 2015 10:29 pm
template works fine on mine
win 8.1 , i3-3220 cpu ,intel hd graphics
ill try on the lap top and see if its ok on that
astra vxr
Post by astra vxr » Wed Feb 11, 2015 10:35 pm
laptop works fine win 7 intell core 2 cpu @1.66 ghz . intel 945 graphics 2gb of ram
Wuniek
Post by Wuniek » Wed Feb 11, 2015 10:38 pm
astra vxr wrote:template works fine on mine
can you check what version of driver you have ?
astra vxr
Post by astra vxr » Wed Feb 11, 2015 10:47 pm
no problem
eugen_troll
Post by eugen_troll » Thu Feb 12, 2015 12:40 pm
Dont work with Windows XP.
ecu dont work.JPG (9.92KiB)Viewed 13358 times
ATS_Scott
Post by ATS_Scott » Wed Feb 18, 2015 10:37 pm
I have experienced a couple of issues. using windows 7, and have seen these issues on 2 different laptops.
I accidentally double clicked the top of the fuel map (using touchpad and I'm clumsy) and it maximized the window. Normally there is a minimize button, but it seems to have disappeared (image attached).
I'm also unable to use the '+" key to add fuel, and the shortcut seems to be correct. "-" key to remove fuel works normally.
Also several windows like the log parameters window have preset size, but it is not big enough to show all options, and the scrollbar is partially covered by the window edge. I am unable to "stretch" it to a usable size. image also attached.
That's all I have seen so far, but switched back to 1.1 RC for now.
ATS_Scott
Post by ATS_Scott » Wed Feb 18, 2015 10:41 pm
Just found another... Graph log#2 and log group analog inputs windows were open, in the background of my Log tab, and the close button is not working...other windows close normally.
astra vxr
Post by astra vxr » Wed Feb 18, 2015 10:47 pm
i found mine did that though it was down to laptop after messing round with software on home pc then putting it on laptop so i guess it wasnt down top me switching :)
Post by Jadzwin » Wed Feb 18, 2015 11:20 pm
HI guys!
Most of the above issues (also XP crash) are solved now.
I will keep you posted..
ATS_Scott
Post by ATS_Scott » Thu Feb 19, 2015 2:14 am
The attached pic shows all the windows I found minimized to a little tiny square, and when I stretch them out I cannot close any of them, like the close button does not exist.
ATS_Scott
Post by ATS_Scott » Thu Feb 19, 2015 6:53 pm
I just noticed something else about the windows I cannot close. They are on every tab. Maybe I just corrupted my desktop.XML
Post by Jadzwin » Thu Feb 19, 2015 8:44 pm
Looks strange. You can always close widnows from Windows menu.
There is a list of all open windows
