Trigger settings for Nissan ca18det s13?
I am looking for the trigger settings on a Nissan ca18det s13. What trigger does it have, some speak about CAS and some about a 24+1?
Is there anyone that has used the factory harness with an adapter and got it to work?
Thanks,
Joakim
Thanks,
Joakim
Re: Trigger settings for Nissan ca18det s13?
Im running adapter loom in my nissan Ca18det.
It is cas settings. Send me an e mail Joakim.
I will also need one of these for a CA18 soon, does anyone have a base settings/tune to share?
thank you
thank you
- Kisielisodd
- ECUMASTER TEAM
proven working configuration
That is perfect, thank you
Can speed meter work with emu?
In your car the signal from gearbox (VR sensor) goes to dashboard and then to ECU.
So your speed should work normally with EMU, and you should provide speed signal from your dashboard to EMU
eugen_troll
Has anyone base ignition timing map for ca18det?
Stock or allready tuned.
Big thx
Big thx
E85 or regular pumpgas?eugen_troll wrote:Has anyone base ignition timing map for ca18det?
Big thx
eugen_troll
Regular pumpgas.PSI-Motor wrote:E85 or regular pumpgas?eugen_troll wrote:Has anyone base ignition timing map for ca18det?
Big thx
Ok. Tnx. Is there any base map for this engine?
- Kisielisodd
- ECUMASTER TEAM
Try this one, it's from our coworker car early configuration
- CA18DET.emu
- (72.82KiB)Downloaded 132 times
what would be a suitable IAT for this setup? I assume built in map is ok...
- ktsirigotakis
on the back of the intake there is a one way valve for the breather i have removed the one way valve and put iat sensor there, i did it because i have an oil catch can its nice and looks like factory location
witch one you've put there?
- Kisielisodd
- ECUMASTER TEAM
- ktsirigotakis
ecu master iat
first start right now!!!!!!!!!!!!1 few problems trying to find solution.
s13 doesn't have fuel pump relay????? i cant find it
- ktsirigotakis
i have some problems with my clt cant find the values to calibrate it dose some have them?
- ktsirigotakis
Thanks psi but i have remove the old wiring due to terible contition. Any way i have fount the problem my friend had marked worng the wirePSI-Motor wrote:Pin 18 in Nissans harness is fuelpump
