Introducing RealDash
janimm
Re: Introducing RealDash
Post by janimm » Tue Sep 05, 2017 8:18 pm
Sorry for the late reply.
The EMU vehicle speed sensor is mapped to 'ENGINE/ECU INPUTS->VSS1' in RealDash.
www.realdash.net
www.facebook.com/realdashapp
@realdashdev
mmt
Post by mmt » Fri Oct 27, 2017 7:15 pm
janimm wrote:
Wed Nov 02, 2016 9:39 am
Jan32 wrote:When do you think comes an Apple version that supports Ecumaster protocoll?
Mac is doable, iOS is currently not (see my reply on previous page).
http://perfecttuning.net/en/ecumaster/1 ... -wifi.html
https://www.youtube.com/watch?v=31uVithmPbo
i use it for 2din android in e46, where the problem bluetoth connection with ecumaster bluetoth unit
it works great
janimm
Post by janimm » Sat Oct 28, 2017 9:14 am
Yes, perfecttuning.net now has a WiFi adapter that enables connection to iOS version of RealDash. I updated my old reply.
www.realdash.net
@realdashdev
adam88sc
Post by adam88sc » Mon Nov 06, 2017 10:20 pm
i've been working on my own dashboard. I like that I can use lambda and lambda target via the app. It would be really nice if i could also add boost target on my map gauge.
Thanks!
Adam
janimm
Post by janimm » Fri Nov 10, 2017 9:16 am
Sorry for the late reply. Unfortunately EMU does not send boost target in its Bluetooth stream.
www.realdash.net
@realdashdev
janimm
Post by janimm » Thu Nov 23, 2017 10:20 am
We have a Black Friday weekend sale for RealDash full version activation. 50% off from normal price.
http://facebook.com/realdashapp
http://instagram.com/realdashapp
If you have been thinking about getting a full version of RealDash, now is an excellent chance!
www.realdash.net
@realdashdev
mmt
Post by mmt » Tue Dec 05, 2017 10:07 pm
I have a problem, I have just edited the indicators of what I need
everything works, but the oil pressure indicator after starting is still at max
10bar
I did not find another input with oil pressure
janimm
Post by janimm » Fri Dec 08, 2017 9:18 am
The EMU oil pressure value is in 'Ecu Specific' category as 'Oil Pressure (Bar)'. You can create gauge and link to that input directly, or you can map this value to work with all dashboards.
How to map Ecu Specific value to common value:
- Go to RealDash Settings->Units->Values->2nd page
- Scroll down to find 'Engine Oil Pressure' on left side
- Press the button on the right and select 'Ecu Specific->Oil pressure (Bar)'
- Tap upper left corner until you are back on dashboard.
Hope this helps.
www.realdash.net
@realdashdev
mmt
Post by mmt » Sat Dec 16, 2017 7:34 pm
THX :mrgreen:
alev8
Post by alev8 » Fri Mar 30, 2018 11:27 pm
Hi RealDash
i just got the full version...made a datalog on it, have the files....but how can i import them to the ecumaster software?
janimm
Post by janimm » Tue Apr 03, 2018 8:39 am
RealDash can generate log file in two formats, CSV and MSL. Try creating a log file as CSV file and import that. To change datalog format:
- Go to 'Settings->Datalogging'
- Tap CSV as datalog format
- Tap upper left corner until back in dashboard.
Next log will be saved as CSV file.
www.realdash.net
@realdashdev
extremy
Post by extremy » Mon Aug 20, 2018 7:51 am
I'm using the pole position dash and everything works fine except for fuel pressure (in BAR). The value displayed is much higher then the actual value.
When I change the fuel pressure, the displayed value also changes, so the input I selected should be correct.
4 bar is displayed as 8, and when I turned the pressure up to 6 bar it showed a value of around 15.
Any idea what I'm doing wrong?
Greets Remy
janimm
Post by janimm » Mon Aug 20, 2018 8:56 am
First check what units you are using:
Settings->Units & Values->2nd page->Use Bar and Kilograms Instead of PSI and Pounds
If that setting is correct, you can apply scaling to your pressure value:
- Go to edit mode and select your Fuel Pressure gauge
- Tap 'Input & Values' and button below 'Select Data Source'
- Select 'ECU Specific->Fuel Pressure (Bar)
- Press small burger menu on that line
- Adjust scale and offset
www.realdash.net
@realdashdev
extremy
Post by extremy » Tue Aug 21, 2018 10:13 am
Thank you sir, hadn't noticed the scaling option. Changed the scale from 1.0 to 0,5 and that did the trick ;)
