Has anyone managed to connect an EMU to an AiM Solo DL Data Logger?
Here's what I have done so far:
1. Connected the EMU to the Solo via the RS232 RX and TX cables which are pin 1 and 2 on the EXT Port
2. Set the Ext Port to "AiM Dashboard" in the software
3. Configured the Solo DL under "Device Configuration" I have set "ECU Manufacturer" = "AIM" and "ECU MODEL" = "PROT_UART"
This doesn't work. The Solo DL doesn't pick up any data.
I have tested the Solo with my Haltech Sprint 500 and it works perfectly via Haltech CANv2.
Has anyone managed to get this working???
Thanks in advance.
Nico
HELP Logging data with a AiM Solo DL
Re: HELP Logging data with a AiM Solo DL
We have tested AIM Pista Dashboard over serial communication and works great.
We didn't tested over CAN however we will do in 1-2 weeks.
Did you try to swap TX and RX ?
What firmware version do you use ?
