Output AFR data to gauge
outrider
Post by outrider » Wed Feb 21, 2018 8:31 pm
Is there a way to configure the EMU to output AFR information as a simple voltage range to drive a gauge? I know I could buy an external wideband and use it as the input for AFR, or use the bluetooth adapter with a universal gauge or tablet or something. I would like to just output a voltage that can drive a standalone gauge.
nolagg
Re: Output AFR data to gauge
Post by nolagg » Sun Feb 25, 2018 6:33 am
Following
shnazzle
Post by shnazzle » Mon Feb 26, 2018 9:12 pm
Following
+1
nolagg
Post by nolagg » Mon Mar 05, 2018 2:55 pm
Bump....
cmj
Post by cmj » Mon Mar 05, 2018 4:01 pm
Not really. There are no analog outputs.
shnazzle
Post by shnazzle » Tue Mar 06, 2018 4:37 pm
I'm guessing it's more a case of being the other way around.
A WBO gauge with an analogue out to the emu
nolagg
Post by nolagg » Tue Mar 06, 2018 4:52 pm
Yeah,even though I have my AEM powered and grounded at the sensor ground ....my aem and emu AF are off a little and always needs to be calibrated which in turn still can't get it perfect. Was thinking of switching to the ecumasters wideband . My tps has the same issue where the voltage will change before and after start up by like 0.2-0.3 volts .
