Get information about latest versions of software
Wuniek
Post
by Wuniek » Wed Feb 11, 2015 9:44 pm
Unfortunately, this version is not stable on windows 8 Intel driver crashes , with 1.1 does not have this problem
Wuniek on Wed Feb 11, 2015 11:02 pm, edited 2 times in total.
- Site Admin
Post
by Jadzwin » Wed Feb 11, 2015 9:57 pm
Crashes instantly after start up ?
I hate intel drivers...
Wuniek
Post
by Wuniek » Wed Feb 11, 2015 10:06 pm
Jadzwin wrote:Crashes instantly after start up ?
ok now i know what happen, in older version when you close app was popup with info do you want close xxx windows
from my observation app crash if number of windows was more than 120, now i clean up one dashboard and application start fine without error but limit dropped for me to about 110 windows
in attachment desktop template that works on 1.1 and crashes on 1.102
PS. The extension emulayout is not allowed.
- Site Admin
Post
by Jadzwin » Wed Feb 11, 2015 10:15 pm
The driver should never crash
We need to investigate this.
Wuniek
Post
by Wuniek » Wed Feb 11, 2015 10:27 pm
Jadzwin wrote:The driver should never crash
before you put too much effort on this lets wait and see if someone else have same problem, because my laptop has few restrictions i cannot overlap:
- corporate windows 8 with company update policy
- old version of intel driver ( i cannot install nothing never)
- 120+ windows is a lot of unnecessary crap
astra vxr
Post
by astra vxr » Wed Feb 11, 2015 10:29 pm
template works fine on mine
win 8.1 , i3-3220 cpu ,intel hd graphics
ill try on the lap top and see if its ok on that
astra vxr
Post
by astra vxr » Wed Feb 11, 2015 10:35 pm
laptop works fine win 7 intell core 2 cpu @1.66 ghz . intel 945 graphics 2gb of ram
Wuniek
Post
by Wuniek » Wed Feb 11, 2015 10:38 pm
astra vxr wrote:template works fine on mine
can you check what version of driver you have ?
astra vxr
Post
by astra vxr » Wed Feb 11, 2015 10:47 pm
no problem
eugen_troll - Posts:35
Post
by eugen_troll » Thu Feb 12, 2015 12:40 pm
Dont work with Windows XP.
- ecu dont work.JPG (9.92KiB)Viewed 13362 times
ATS_Scott - Posts:113
Post
by ATS_Scott » Wed Feb 18, 2015 10:37 pm
I have experienced a couple of issues. using windows 7, and have seen these issues on 2 different laptops.
I accidentally double clicked the top of the fuel map (using touchpad and I'm clumsy) and it maximized the window. Normally there is a minimize button, but it seems to have disappeared (image attached).
I'm also unable to use the '+" key to add fuel, and the shortcut seems to be correct. "-" key to remove fuel works normally.
Also several windows like the log parameters window have preset size, but it is not big enough to show all options, and the scrollbar is partially covered by the window edge. I am unable to "stretch" it to a usable size. image also attached.
That's all I have seen so far, but switched back to 1.1 RC for now.
Post
by ATS_Scott » Wed Feb 18, 2015 10:41 pm
Just found another... Graph log#2 and log group analog inputs windows were open, in the background of my Log tab, and the close button is not working...other windows close normally.
astra vxr
Post
by astra vxr » Wed Feb 18, 2015 10:47 pm
i found mine did that though it was down to laptop after messing round with software on home pc then putting it on laptop so i guess it wasnt down top me switching
astra vxr on Wed Feb 18, 2015 11:22 pm, edited 1 time in total.
- Site Admin
Post
by Jadzwin » Wed Feb 18, 2015 11:20 pm
HI guys!
Most of the above issues (also XP crash) are solved now.
I will keep you posted..
Post
by ATS_Scott » Thu Feb 19, 2015 2:14 am
The attached pic shows all the windows I found minimized to a little tiny square, and when I stretch them out I cannot close any of them, like the close button does not exist.
Post
by ATS_Scott » Thu Feb 19, 2015 6:53 pm
I just noticed something else about the windows I cannot close. They are on every tab. Maybe I just corrupted my desktop.XML
- Site Admin
Post
by Jadzwin » Thu Feb 19, 2015 8:44 pm
Looks strange. You can always close widnows from Windows menu.
There is a list of all open windows
