Hi my friends, i' m new at programming...my engine firing order is 1342 with wasted spark directly to emu (1212, g8g16g8g16 pins), the injectors are full sequential, are also 1342 ??
my trigger type is bosch 60-2 with vr, and ignition angle is 114BTDC, First trigger tooth is 19 (114/6) ??
i have fuel and spark but don't start
i have a lot o of questions!!!
thanks a lot.
punto gt with emu
Re: punto gt with emu
hi my friends, i have two qestions, 1) emu connect only with wideband knock? i have the oem knock (punto gt knock) and from 0,7 to 5 value (min tps to max tps) with pressure or not, i give only the frequency value from my Car piston diameter (7.2khz) what it's need to work? , i'm new at sport....
2) how can i measure trigger angle with ignition light, because at flywheel where the numbers it can't be (turbo take place), at the other side at belts i have only one point, i must find numbers to write?
