E46 Instrument Panel CAN-BUS
nyl
Post by nyl » Tue Mar 03, 2015 5:22 am
Hey, planing on using one with EMU on my calibra since my instrument panel doesn't work that well, any tips on wiring? a wiring diagram maybe?
b45
Re: E46 Instrument Panel CAN-BUS
Post by b45 » Sun Sep 06, 2015 4:25 am
Curious about this one too. help..
SUKHOI
Post by SUKHOI » Sun Sep 06, 2015 10:27 pm
It should work fine, I have started BMW e46 using EMU + DBW Module + CAN BUS Module, its very easy just connected the 2 CAN BUS wires from module to the cluster with the right resistor and worked fine :)
Post by Jadzwin » Mon Sep 07, 2015 1:54 pm
magelius
Post by magelius » Mon Oct 12, 2015 10:05 am
I am new in this forum, just made my account. I am now searching different ECU options to my BMW E46 -99 328i Coupe (3.0i turbo swap). I have question according to the CAN-bus and stock E46 instrument cluster.
Which instrument cluster meters and warning lights can be controlled via the CAN bus?
I may have to use the M3 instrument cluster, because it has 0-9000rpm range in tacho and 0-300kph in speedo. Can the Ecumaster control different types E46 clusters? Original 0-7000rpm and M3 0-9000rpm? How about the M3 tacho LEDs?
Can the Ecumaster use the original speed signal from the ABS/ASC box and then control the instrument cluster speedo via CAN-bus?
What other CAN functions Ecumaster has already with the E46 CAN-bus?
Are you planning to develop more CAN-bus functions/integration/features to BMW E46?
Post by Jadzwin » Wed Oct 14, 2015 7:33 pm
For E46 cluster the following gauges are supported:
RPM, CLT, check engine light, Drive by wire error, overheat light, oil temperature, alternator light
For E46 M Power:
RPM, CLT, check engine light, Drive by wire error, overheat light, shift light (limit must be set in Shift Light EMU options), oil Temperature, alternator light
The speed is provided by square wave directly to cluster (not via CAN).
Actually EMU doesn't read the speed from ABS (it seems that is on different CAN line).
magelius
Post by magelius » Sat Aug 06, 2016 1:04 pm
Does the EMU have any extra functions via CAN? It would be very nice if you can control the EMU via e46 steering wheel buttons. E.g.activating launch control/rolling launch, adjusting target boost, activating cooling fan etc.
