Bluetooth module and android device
gjhome
Post by gjhome » Wed Sep 10, 2014 10:45 am
I hope you can help my to get my bluetooth module running. I can't find any instructions on this.
What I want to know is the code for pairing with the android device.
I also wonder if there is any requirements on the device, android version etc. What is the best device to get that is known working good?
I want a smaller tablet for fixed mounting in the car.
Best Regards
Gustav
Kisielisodd
ECUMASTER TEAM
Re: Bluetooth module and android device
Post by Kisielisodd » Wed Sep 10, 2014 12:04 pm
Code is 1234 for paring
Both vems display, and ecumaster unfinished app works 7" and 10" table. I tried Vems dislay and ECUMaster app on phone with 3.5" screen and it worked ok.
killerbee
Post by killerbee » Fri Sep 12, 2014 4:42 pm
I have problem with my Bluetooth module , I've tried 2 cars with EMU and 3 android devices - 2 phones and 1 tablet . Every time I pair new android device it connect with Vems Display for 2 seconds - in upper part of screen it shows 1hrz then 0 hrz and disconnect - then this android device can not be connected again - I must unpair then pair and again it has connection only for 2 seconds . Can someone help me with this problem .
Firmware used - first car 0.9xx , second 1.0xx , tried 3 or 4 vems display version - same
Post by Jadzwin » Sat Sep 13, 2014 12:40 am
We had only such problems on Lenovo tablets. On Samsung / Sony Vems display works great.
Here is our guide how to connect to Vems Display. Please check if your way was the same.
BT module to vemsdisplay.pdf
(718.81KiB)Downloaded 225 times
killerbee
Post by killerbee » Sat Sep 13, 2014 7:50 am
Today will get Samsung tablet to test
gjhome
Post by gjhome » Thu Sep 18, 2014 8:39 am
Now I have tried with two different Samsung devices and I get exactly the same problem as the previous user. Vems shows connected for 0,5 sec the it stops.
The LED on the bluetooth adapter never stops flashing. I doesn't work with your own app either. It just hangs.
I use the latest firmware and the latest test version of the software. Please help! :)
Thanks!
//Gustav
Post by Jadzwin » Thu Sep 18, 2014 2:21 pm
So please contact us at info(at)ecumaster.com, we will replace your BT module.
killerbee
Post by killerbee » Fri Sep 19, 2014 4:54 pm
Asus tablet - do not work
Huawei phone P1 - do not work
THL w200s octa core - do not work
Samsung galaxy s3 mini - work :)
ktsirigotakis
Post by ktsirigotakis » Wed Feb 04, 2015 1:14 pm
Hi to all i am interesting to bay a 2din chines radio that have android inside will they work with emu Bluetooth?
for example:
http://www.aliexpress.com/item/2DIN-Cap ... 90384.html
