Version 1.112
Get information about latest versions of software
Version 1.112
Post by Jadzwin » Wed Mar 18, 2015 4:19 pm
Hi There!
There is new software version 1.112
Now the EMU file are associated with application so the user can just press on emu, emulog, emuscp file and the client will open.
Division operator added so now you can divide the cells value (eg. 2/ divides all selected cells by 2)
EMU CAN protocol modified and new data frame 0x605 added.
There is also improvement for idle control in ALPHA-N. Now the idle valve DC can influence VE table (DC VE Correction table)
Angelo S38
Re: Version 1.112
Post by Angelo S38 » Thu Mar 19, 2015 12:19 am
Is anyone experiencing the same error when you open the program? Didn't get this on the previous versions.
Re: Version 1.112
Post by Jadzwin » Thu Mar 19, 2015 12:44 am
Looks like you do not have adiminstrator rights to register file extension in registry.
Try to start application as administrator.
ATS_Scott
Re: Version 1.112
Post by ATS_Scott » Thu Mar 19, 2015 6:04 pm
I got it on both my laptops, but not logged in as admin either.
Wuniek
Re: Version 1.112
Post by Wuniek » Thu Mar 19, 2015 9:44 pm
ATS_Scott wrote:I got it on both my laptops, but not logged in as admin either.
if you can, try :
and to support , division function don`t works for me :( i want simply make 3 steps:
open AFR based map
change fuel strategy to advance
and divide all by 1.47
Angelo S38
Re: Version 1.112
Post by Angelo S38 » Fri Mar 20, 2015 12:01 am
Thanks for the tip, that did the trick for me.
ATS_Scott
Re: Version 1.112
Post by ATS_Scott » Fri Mar 20, 2015 1:08 am
Worked for me too, Thanks!
killerbee
Re: Version 1.112
Post by killerbee » Mon Mar 23, 2015 6:26 pm
I updated from 1.1 and it do not work , try to uninstall put 1.1 again - no problem but 1.112 do not work on XP , here is the error
Alec
Re: Version 1.112
Post by Alec » Tue Mar 24, 2015 3:15 am
I had the same issue and running as administrator fixed it.
killerbee
Re: Version 1.112
Post by killerbee » Tue Mar 24, 2015 7:17 am
This error is while logged as administrator , I check this twice
killerbee
Re: Version 1.112
Post by killerbee » Tue Mar 24, 2015 10:30 am
I 've tested my other laptop , everything is good but when car starts it disconect and conect only when car is bot running
Re: Version 1.112
Post by Jadzwin » Tue Mar 24, 2015 2:28 pm
In next version the application will force the system to run as administartor. I think it helps.
Divisin bug will be also fixed
Ralf
Re: Version 1.112
Post by Ralf » Mon Mar 30, 2015 6:17 pm
If I got it right, these registry keys are just create once, so why not just creating the registry keys during setup? There you have admin rights anyway and the application does not require permanent admin rights for running.
Re: Version 1.112
Post by Jadzwin » Mon Mar 30, 2015 7:14 pm
In next version it will be done in that way..
Tomek_P
Re: Version 1.112
Post by Tomek_P » Mon Mar 30, 2015 8:04 pm
killerbee wrote:I updated from 1.1 and it do not work , try to uninstall put 1.1 again - no problem but 1.112 do not work on XP , here is the error
I have the same problem.
BMW e30 M50B25 +turbo
killerbee
Re: Version 1.112
Post by killerbee » Tue Mar 31, 2015 6:17 pm
Will wail till next version , meanwhile changing USB cable help me to work with my other laptop ...
Jan32
Re: Version 1.112
Post by Jan32 » Sun Apr 05, 2015 10:38 pm
Hi guys,
the function enable log and look at values with password protection does not work. When i activate the password protection emu Is locked and i can do nothing else.
Re: Version 1.112
Post by Jadzwin » Tue Apr 07, 2015 6:31 pm
Jan32: It works. Just press enter or enter wrong password. Then the new message box appears.
Jan32
Re: Version 1.112
Post by Jan32 » Sat Apr 11, 2015 11:30 pm
I tested it and it works. Thanks Kuba.
killerbee
Re: Version 1.112
Post by killerbee » Sat Jun 06, 2015 7:50 am
There is problem conecting with dropbox to download fitmware
