Hei
We have some problems with a Nissan CA18DET engine. the coils will not spark.
The coils need ground from the ECU, but gets + (see pic).
We use the Nissan trigger, and all wire is okay
hope some one can help.
KK Autoteknik
spark problems[SOLVED]
- ca18det.emu
- ca18det
- (77.96KiB)Downloaded 61 times
- signal cyl. 1
- signal cyl. 1.png (9.94KiB)Viewed 1920 times
Re: spark problems
Change coil type in Ingtion / outputs to coil without amplifier.
Re: spark problems
We have trying doing that, but there is no change
Re: spark problems
Can you send the log file and scope file ?
Re: spark problems
We have fix the problem.
I have forget to connect the power ground cables,
sorry for the inconvenience
KK Autoteknik
KK Autoteknik
