I have setup launch control to activate using Input 4. I am getting a clean 4.96v when switch is active. Launch control is not activating?
I can see the voltage in the client window and have triple checked my settings. Launch control works when set to always active but thats it.
Am i doing something wrong?
I have just found the 1.32 Firmware for the DET3 client so i will try again with that tomorrow..
Launch control?
- ktsirigotakis
Re: Launch control?
its better to use ground than 5v the only thing you have to do extra is to select the box that says inverted
analog 4---switch----ground
Re: Launch control?
Ill give that a go in the morning! thanks
Re: Launch control?
That doesnt work.. the analogue input is always 0v so, putting a switch to ground does nothing. The launch control stays on constant when i do it this way as inverted sets it to come on when input is lower than 4.8v which it is always..
I originally had:
An4 - switch - 5v
Now i have
An4 - switch - Grnd
I see the frequency input uses pullup somehow but i cant read the rest of the text on the option.. very frustrating as it doesnt work as it should. It should work with the 5v input.
I originally had:
An4 - switch - 5v
Now i have
An4 - switch - Grnd
Re: Launch control?
So i had to learn how pullup resistors work when grounding a freq input. have launch control working now
- ktsirigotakis
Re: Launch control?
the best thing you have done i was in harry and didn't explained it to you that day
Re: Launch control?
hi. can you tell me how you have done?
