Detonation
Has anybody a log/picture of a detonation ?
I have no idea what to look for or how high the spikes are.
Grts
Patrick
Grts
Patrick
Re: Detonation
20Hz logging is useless for trying to see knock events from the Knock Sensor Value channel. You can see knock events with 20Hz logging through the Knock Action channels after it's all been set up correctly.
Re: Detonation
You mean 20hz is not fast enough. You can only check the result => the reaction in ignition or fuelling ?Kurt wrote:20Hz logging is useless for trying to see knock events from the Knock Sensor Value channel. You can see knock events with 20Hz logging through the Knock Action channels after it's all been set up correctly.
Re: Detonation
Kurt you are not right.
The logger is quite smart and it show the maximum value of knock level , voltage and all cylinders on what there was detonation between each log frame.
So even the log works 5Hz you still will see any knocking and you will get information what cylinder was involved.
Re: Detonation
JadzwinJadzwin wrote:Kurt you are not right.
You have an example ?
Re: Detonation
Very good info! Glad to be wrong about it.
I've noticed that Knock Ignition Event will show 1 or more cylinders for a given data point. So, if the log shows a cylinder in Knock Ignition Event, will the Knock Level value at that point correspond to that cylinder?
Can you please explain what we're seeing with Knock Sensor Value and Knock Level? I'm certain (from bench testing) that the Knock Sensor Value channel will NOT always show a spike when a knock impulse is induced and knock ignition retard is activated. I did not pay attention to Knock Level, though.
I use Knock Sensor Value data to set Engine Noise table and just ensure through sound recordings that the data is 100% certain knock free. Is this channel showing only peak levels, average, or simply current value at each sample point?
Re: Detonation
Hi Kurt!
I will check it after weekend again.
However knock level and knock sensor value should be the peak value between samples.
If knocking on multiple cylinders occurs between 2 log frames, you know only the peak value of knock level on one of the marked ignition events.
Howver the goal is to keep knock level equal to 0.
Re: Detonation
So is this knock or engine noise ?
(2.59V is knock output.)
I think 2800 rpm, 24.5°ign and 84 map is not really knock condition.
I have just installed the new soft so i think i have to adjust something , not ?
You see (bad) on the bottom the ignition retard taking 10° action. So before spike advance was 34°.
Re: Detonation
Engine Noise 2D table is used to calibrate noise level of normal engine operation on whole RPM range. If Knock sensor value exceeds Engine noise from table, it is interpreted as engine knocking. This difference is named Knock Level. Higher Knock Level means more severe engine knock.
So first you need to build your engine noise table based on non knocking engine based on knock sensor value. Then if the knock occurs the knock level will be > 0.
In next week we plan to release the 1.1 official version. There will be help in English for every EMU option so all information about knock sensing will be available.
Re: Detonation
Question for those who know:
Is it possible that hard engine mounts (very hard, but not welded stiff!) influence the knock sensor signal? I think with my Knock signal something is wrong, as it reaches up to 4,2V @ 7000 RPM redline. Engine is SR20DET with some mods @ 0,3 bar boost and standard knock sensor. when rolling down a hill with deceleration cut, value is at approx 0,7V and when idling at 1,4V. When engine starts up, the value spikes up to almost 5V.
I somehow lost a part of the log (accidentially closed the log
) and have just a few smaller revs on the safed log attached down there.
I have not connected an aplifier to the sensor signal yet, to listen to the sensor via headphones, but I surely will do that soon.
Which Knock sensor values should approximately be read on this engine?
THANKS!!
THANKS!!
- 20150412_1725.emulog.txt
- (466.04KiB)Downloaded 138 times
Re: Detonation
I've heard of cases involving stock vehicles where something as simple as a poorly fitted exhaust that hits or rattles against the chassis under load can cause a false knock reading. It's entirely possible that a metallic rattle from something attached to the engine produces enough noise to be picked up by the knock sensor. It's also worth inspecting your wiring and grounds just as a precaution.
