Turbo Control
Hello
have a problem with my turbo pressure
I'm not over 0.4 bar
my motor is a Z20LET
- 20150323_1723.emulog
- (1.31MiB)Downloaded 111 times
- 20.04.2015.emu
- (77.75KiB)Downloaded 129 times
Re: Turbo Control
what boost control valve are you useing ?
also whats with the spark map ?
Re: Turbo Control
I have the original Turbo with valve control.
Ignition map I have not yet been set.
Are you a base map for me?
Thank you Peter
Thank you Peter
Re: Turbo Control
i dont have a map as of yet
why are you trying to put boost through the engine when its not mapped off boost ?
looking at the data log you dont even see wot
even on crap fuel you can run a little bit more timing than 10-12 deg even on boost its so far retarded its unreal i havent had a good look at everything as of yet as im useing a tablet to read this on but i will have a look when i got home on a bigger screen
Re: Turbo Control
just seen something
primary trigger settings dont look right
first tooth trigger ( there isnt a number )
trigger angle ( 117 deg ) thats not right
1st tooth trigger is 9
trigger angle is 60
trigger angle is 60
Re: Turbo Control
You can start with that ignition, maby take out a couple of degres to be safe.
Re: Turbo Control
PSI-Motor wrote:Ignition map.
is that from the file posted ?? if so i must be doing something wrong as ive loaded the same one and i have differnt settings ???
Re: Turbo Control
astra vxr wrote:just seen something
trigger angle is 60
60-2. 117 degres is almost the same as tooth 9 and 60 degres, tooth 9 + 60 degres is 114.
Re: Turbo Control
PSI-Motor wrote:No i did a ignition map for him
ha ha though i had loaded up the wrong file
no that will be fine at that prob could add a bit more to it but it will be well safe for that engine more worring is the trigger setup ?
Re: Turbo Control
astra vxr wrote:PSI-Motor wrote:No i did a ignition map for him
ha ha though i had loaded up the wrong file![]()
He he
The trigger setup is almost correct, depending on ignitionsystem delay it should be 114-117 degres. But it is a VR sensor standard if my memory serves me correct
You can choose to do teeth count as you said or just use the angle as he did. I would like to see a scope log and se if the polarity of the sensors are correct.
Re: Turbo Control
dumb mode kicked in yes correct i think its lack of sleep for me there are some little differences in the vauxhall engines (more so the 2.0 )PSI-Motor wrote:astra vxr wrote:just seen something
trigger angle is 60
Re: Turbo Control
if its a z20let sensor it should be a hall sensor (80% sure ) and so is the cam sensor(100%sure ) as its the z20let z20 leh and the z20ler engines that use this sensor and nothing else if it was the vr then it could be used on the 8v and the 2.0 xe or let enginesPSI-Motor wrote:astra vxr wrote:PSI-Motor wrote:No i did a ignition map for him
He he
Re: Turbo Control
hey
my scope does not know not how I set it
the motor has a hall sensor
will try the ignition map
thank you
Peter
thank you
Peter
