BMW M20 Cam sensor
Nicky761
BMW M20 Cam sensor
Post by Nicky761 » Mon Oct 29, 2018 5:04 pm
Does anyone have a method for creating a cam sensor on the BW M20 engine? In stock trim BMW uses a coil around the #6 spark plug wire to detect cam location. Can this sensor be made to work?
Thanks for the help.
'87 BMW E30 track car
Schlander
Re: BMW M20 Cam sensor
Post by Schlander » Mon Nov 05, 2018 12:35 am
Here's your answer, works like a charm on my engine.
https://www.ebay.com/itm/BMW-M20-M30-bi ... 3621795090
Nicky761
Post by Nicky761 » Mon Nov 05, 2018 3:57 am
Very clever and simple. Now I have to ask you about which coils and plugs you used. Do you have any pictures of the mounting? Thanks
Schlander
Post by Schlander » Fri Nov 09, 2018 12:34 am
M20B25 block 86mm 3.123ccm
M54B30 crank 89,6mm
M54B30 rods 135mm
JE pistons 86mm 12.5:1
Ported 885 head
Schrick 288
NUKE camgear
RHD itb’s
RHD flywheel 3,7
Hartge manifold
Ecu Master ECU
Bosch 3x2 wasted spark
E34 M5 3,6 injectors
Adjustable Malpassi fuel pressure regulator
ImageUntitled
Schlander
Post by Schlander » Sun Jan 06, 2019 10:17 pm
The file is attached here Nicky761.
But you can't use the ign table or fuel table when our engines are different. But some settings should do.
PhillipHamilton Rullefelt 264hk 327nm - 2.emu
EMU file
(103.33KiB)Downloaded 107 times
Nicky761
Post by Nicky761 » Sat Jan 12, 2019 2:40 am
