ABS to ECU by canbus
Horsty
Post by Horsty » Fri Apr 24, 2015 1:36 pm
hi there,
can i wire an ITT Mark20 Plus ABS (+ is the one with canbus) directly to the ecu?
i wanted to do so because then i could use the ABS as VSS.
cheers,
Re: ABS to ECU by canbus
Post by Jadzwin » Fri Apr 24, 2015 1:59 pm
Hi Horsty!
For example in Mini Cooper we read wheel speed from ABS ECU via CAN Bus.
So it is possible but we need to know what CAN ID transmit wheel speed and what is the data format.
Horsty
Post by Horsty » Sat Apr 25, 2015 2:37 pm
thank you!
i have to check that somehow...
Wuniek
Post by Wuniek » Sat Apr 25, 2015 3:40 pm
you will need connect to car CAN and somehow listen to it ... :
https://youtu.be/hpwBmTw7Gm0
http://goodfet.sourceforge.net/hardware/goodthopter12/
Horsty wrote:thank you!
Post by Jadzwin » Sat Apr 25, 2015 10:22 pm
You can buy Microchip CAN BUS analyzer. It is quite chip and very helpfull
Horsty
Post by Horsty » Sat May 02, 2015 12:02 am
ok thank you.
i have to do this somewhere in the future.
but i'll let you know!
b45
Post by b45 » Sun Mar 13, 2016 10:34 am
Jadzwin wrote:You can buy Microchip CAN BUS analyzer. It is quite chip and very helpfull
I bought canBus analyzer from microchip. Try to hook it up into canBus cable beneath steering above foot rest. But no luck. Any step by step guide doing this into bmw E46?
