BMW e36 sensors calibration
Need help to calibrate water temp and IAT sensors. 13621739510 is the IAT, 13621703993 is the CLT sensor part numbers ... i measured the IAT resistance to 6300 ohm at ~20C degree, but when i calibrate it in the ecu, it sees -6 degrees ... something is not ok so i need help to set up my DET3
Re: BMW e36 sensors calibration
hello, I wanted to ask you something. on which engine you have mounted the ECU? m50 or m52 ? if m52, can you write how mounted it? I 'm coming out crazy. thanks
- ktsirigotakis
factory bmw sensors work perfect with det3 they don't need calibration use the pre installed calibrations
my problem is that in the assembly diagrams there is not my engine ( m52 ) , but the m50 . then I'm going crazy
- ktsirigotakis
find it by your self by using the multiplier i have done it meany times!!!
it was easy . eg I have the maf and in the pinout of the ecu there is not an output signal for the maf. how can I do? I have to connect the pin 17 to the ground of maf ?
