Need ignition contrl DET3 for Suzuki Splash
DET3 technical support
Baroto
Post by Baroto » Fri May 01, 2015 8:47 pm
hi. im Baroto from Indonesia.
I have 2pcs DET3. and I buy from ECUmaster Poland with Mr Piotr. i want to be a sole agent in indonesia.
i have problem with ignition retard/advance for my car. the Crank trigger is 36-2-2. and no patern trigger in new software. i asking by email and until now i dont have any new update.
as attach is my collecting data from my car.
and i request new feature for flat shift. thanks before.
best regards
baroto
signal test ECM Suzuki splash.pdf
signal test for suzuki splash.
(1.78MiB)Downloaded 173 times
36-2-2 trigger scope
installation in my suzuki splash
b45
Re: need firmware DET3 for Suzuki Splash
Post by b45 » Sun May 03, 2015 3:51 am
Looks like a 12-2 24-2 to me.
Baroto
Post by Baroto » Mon May 04, 2015 11:57 am
yes. it's like 12-2 and 24-2.
but i don't know how to calculate the trigger plate.
as attach is my trigger plate and how to test the signal in my car.
(1.78MiB)Downloaded 198 times
Baroto
Post by Baroto » Tue Jun 09, 2015 7:46 pm
Hellow.....
Any one can help with my problem???
Baroto
Post by Baroto » Thu Oct 29, 2015 7:51 pm
im waiting for firmware 1 year.
hiks.... now im still waiting. :cry:
putani
Re: Need ignition contrl DET3 for Suzuki Splash
Post by putani » Sat Jun 18, 2016 3:22 pm
hi barto will you please help me in the wiring of det3 on the suzukis
LIVE LIFE FORCED INDUCTION
Baroto
Post by Baroto » Sun Jul 03, 2016 6:55 pm
putani wrote:hi barto will you please help me in the wiring of det3 on the suzukis
Hellow
Which model suzuki?
Kisielisodd
ECUMASTER TEAM
Post by Kisielisodd » Mon Jul 11, 2016 4:56 pm
From Unknown reason 36-2-2 trigger from subaru and similar in swift do not work with det3, so we removed support trigger from list.
Tomorrow we will try to add support of the trigger. We arranged swift with M16A engine and we will work on trigger decoding
**update**
We did test's on car, we have found a mistake, hope we will be able to release new firmware version with 36-2-2-2 support.
Because of technical reasons maximum 9 degree of ignition advance will be possible.
felipeandrest205
Post by felipeandrest205 » Fri May 04, 2018 8:46 am
**update**
Sorry for attach to this post but I want to know if the DET3 is capable to work with with M15A ECU and M16A engine, I had done a M16A swap in my Swift 1.5VVT and I would like to use the FIT MODE to raise the rev limit at least to 7500rpm, plese tell me if this is possible. I had installed a DET3 on my Celica GT4 and works awesome. So would like to use it on my Swift :)
Regards
