s50b32 cam sync problem
mmt
Post by mmt » Tue May 05, 2015 6:38 pm
hi
i have s50b32 turbo non vanos ,i used for intake tothwhel of s50b30(exhaust) and   jadzvin advised me
remove three teeth,and use misingtoth
Tried here as the Hall sensor,as well as VR, But I still have the same problem
the engine is not running well, so when you add gas misfires!!!
Any ideas
THX
Re: s50b32 cam sync problem
Post by Jadzwin » Tue May 05, 2015 7:23 pm
Please attach the log and project file
mmt
Post by mmt » Tue May 05, 2015 7:30 pm
Jadzwin wrote:Please attach the log and project file
20150505_1655_35.emu
(85.27KiB)Downloaded 154 times
scope_201555_181problem s hall senz.emuscp
(401Bytes)Downloaded 123 times
20150505_1504cukani pri plynu.emulog
(1.67MiB)Downloaded 129 times
mmt
Post by mmt » Tue May 05, 2015 7:41 pm
Post by Jadzwin » Tue May 05, 2015 7:53 pm
Looks like signal noise from cam sensor.
You can try 2 missing tooth decoder.
Hoever I think the only solution is to disable cam sensor over 600-700 RPM
mmt
Post by mmt » Tue May 05, 2015 8:58 pm
Jadzwin wrote:Looks like signal noise from cam sensor.
tried HALL sensors connected here, and VR
but interference with VR was smaller
trigger type I tried them all, but either did not start or still the same problem
Tomorrow I'll try to disable cam senzor
Post by Jadzwin » Tue May 05, 2015 9:53 pm
Actually to fully diagnose the problem you need to use scope and check the signal shape, noise and so one.
mmt
Post by mmt » Tue May 05, 2015 10:07 pm
Jadzwin wrote:Actually to fully diagnose the problem you need to use scope and check the signal shape, noise and so one.
do not oscyloskop available
I have to ask a friend to help me
The fastest solution for me is to try to disable the cam sensor,for now
Post by PSI-Motor » Tue May 05, 2015 11:22 pm
I used the standard VR Sensor with Hall and pullup settings. Works perfect. Do you use a sheilded cable all the way?
If you are not planing on running Vanos you can just disable it över 600rpm.
mmt
Post by mmt » Wed May 06, 2015 12:58 pm
PSI-Motor wrote:I used the standard VR Sensor with Hall and pullup settings. Works perfect. Do you use a sheilded cable all the way?
yes I used bmw oem cable from vr sensor , with shielding
I plan to use without vanos
