BMW V8 trigger doubt
Hi guys, I have BMW v8 m60 and although runs good and high rpm sound its great, but think that dont work correctly all cylinders. Injectors and coils are wiring 1+6, 5+3,4+7, 2-8, firing order is 1-5-4-8-6-3-7-2. With this, theoretically ignition and injection events should be 1342, 1342 but don´t start. Currently my events are 1234, 1234. Wiring pairing has been checked, test output done and dont get start with correct order. Any idea?
The fun starts now
Re: BMW V8 trigger doubt
order 1342 1342
first tooth 6
angle 51
1-4 passenger side
5-8 driver side
so i think you are only cca 18degree wrong
first tooth 6
angle 51
1-4 passenger side
5-8 driver side
Very difficult start it with this setting, and when get it, its a disaster, intake explosions, only a few cylinders works ....
The fun starts now
You must have some mistake, i have done many M60,M62 engine, they work like that.... Maybe you dont have correct trigger angle or you have some noise on crank signal.
Backfire means, you are firing cilinder when intake valves open, so you need to fire way more later
Exactly. I’ll try change trigger angle in interval of 5 in 5 angles.
Have you used this trigger settings In all yours m60?
The fun starts now
Still with this problem. From 3000rpm and dont get exceed 6300/6400 rpm. Any advise?
Its correct wiring 1+6 5+3 4+7 and 2+8?
The fun starts now
