yet another cam sync question
alper
Post by alper » Sun May 10, 2015 10:22 pm
on the sierra DOHC engine, I have a cam vr sensor that's pointing the camshaft lobe.
everything works fine for sequential injection. - well - until around 4000 rpm.
after then, when revving, bursts and blasts start.
is that a 'noise' problem ? what if I choose the "disable cam sync above 1000 rpm ?
Emu Distributor / Tuner
knastbigger
Re: yet another cam sync question
Post by knastbigger » Mon May 11, 2015 6:46 am
Try to log the 2 trigger parameters
TRIGGER ERROR
TRIGGER SYNC STATUS
alper
Post by alper » Mon May 11, 2015 9:28 am
there are NO errors / syncronization loss.
derOJ
Post by derOJ » Mon May 11, 2015 11:40 am
i had the same problem yesterday and took a look into manual.
i think i solved it now, by noise filter.
i set 700° of crank angle to ignore any cam trigger.
maybe it will help you too
Post by Jadzwin » Mon May 11, 2015 12:39 pm
Please check the following documentas according Cossworth ignition system:
https://dl.dropboxusercontent.com/u/286 ... otesv2.pdf
https://dl.dropboxusercontent.com/u/286 ... %20IAW.pdf
alper
Post by alper » Mon May 11, 2015 1:40 pm
yeah but this is not cosworth.
cosworth has no pronblems.
this is Ford Sierra N7A DOHC. (not cosworth engine)
Post by Jadzwin » Mon May 11, 2015 1:48 pm
AAA :) Please attach the log file here
