ignition problem Opel Z20LET
peter1002
Post by peter1002 » Sun May 10, 2015 6:31 pm
Hello
My engine runs normally when it is cold
when it is hot it is running on only three cylinders under 2,000 rpm
when I go over 2000rpm it is running normally
the ignition module and the spark plugs are new
Good day
10.05.2015 log.emulog
(1013.24KiB)Downloaded 134 times
10.05.2015.emu
(86.52KiB)Downloaded 150 times
roquete
Re: ignition problem Opel Z20LET
Post by roquete » Sun May 10, 2015 11:25 pm
Hi, i think you injector sequence is wrong, check Fuelling-Injectors phase
astra vxr
Post by astra vxr » Sun May 10, 2015 11:31 pm
when its cold engine like a bit more fuel but its pig rich when its warm a z20 wil idle at 15 afr all day long but i tend to keep it a little richer but your log is al over the place and some places its well into the 10`s around 1000-1200 rpm hence why its going to run ruff it carnt burn that amount of fuel at such low rpm i wouldnt even put a car running 2 bar of boost under that sort of fueling lean it out under 2k and see if that helps it run a bit better aim for around 14 ish afr and see how you get on
peter1002
Post by peter1002 » Mon May 11, 2015 11:11 am
Hello
the engine is running so fat because he has been working on three cylinders
Post by Jadzwin » Mon May 11, 2015 12:21 pm
The engine is not working on particulart cylinder or it is random ?
peter1002
Post by peter1002 » Mon May 11, 2015 1:21 pm
It is always the fourth's. I have also tryed an other ignitionoutput on the ECU.
Post by Jadzwin » Mon May 11, 2015 1:26 pm
Maybe to coil or injector are broken ?
astra vxr
Post by astra vxr » Mon May 11, 2015 2:11 pm
coil or injector could also explain the afr as sometimes its ok and other times it looks ok
astra vxr
Post by astra vxr » Mon May 11, 2015 2:14 pm
are you useing the standard z20 coil ?? if so that could be the problem as they arent very good at the best of times
peter1002
Post by peter1002 » Mon May 11, 2015 3:28 pm
ignition module is new
Injector I have exchanged 3-4
derOJ
Post by derOJ » Tue May 12, 2015 8:09 am
peter1002 wrote:Hello
But an unburned Mixture of one cylinder will cause a lean afr
peter1002
Post by peter1002 » Tue May 12, 2015 4:38 pm
Hello
have today Engine compression tested 12.9 bar all 4
cable from the ECU to kündmodul I also dipped
and also fat and lean gestelt
still the same problem
astra vxr
Post by astra vxr » Tue May 12, 2015 5:59 pm
is it still on number 4 only ??
have you swaped injector plugs around and altered software to suit that will rule out injectors drivers on ecu
if the problem is still there after that the is either injector , plug or coil
peter1002
Post by peter1002 » Tue May 12, 2015 8:18 pm
have it all changed still the 4 cylinder
Today I drove 20 min normal then it started again
astra vxr
Post by astra vxr » Tue May 12, 2015 9:58 pm
how old are the plugs ?
its pig rich what ever the problem is
have you a differnt coil pack to try even though yours is new i would change it for another one and try it
i still think it might be a problem with coil pack getting hot and breaking down or dwell is wrong and its over heating
on a side note : best coil pack if you are running wasted spark is the ecotec one one we used them for years with 3 bar of boost and never had a problem with one
peter1002
Post by peter1002 » Tue May 12, 2015 10:59 pm
the plugs is new
and how is it a setting that I that they stay cold
astra vxr
Post by astra vxr » Wed May 13, 2015 12:01 am
have you swaped injectors around ( swap 2 with 4 )
what coils do you have ( standard z20let one )
peter1002
Post by peter1002 » Wed May 13, 2015 12:39 am
Yes Bosch standart
peter1002
Post by peter1002 » Thu May 14, 2015 4:22 pm
here I still have the connection diagram
and scope
scope_2015514_1447 15.05.2015.emuscp
(280Bytes)Downloaded 123 times
20150514_1523 15.05.2015 log.emulog
(714.23KiB)Downloaded 116 times
15.05.2015 emu.emu
(86.54KiB)Downloaded 120 times
peter1002
Post by peter1002 » Thu May 14, 2015 4:24 pm
fotos
