TPS and Stepper motor. Audi
Doofy
Post by Doofy » Wed May 13, 2015 1:27 pm
My project Audi 2.2t AAN.
But it does not have a stepper motor idle.
I thought to put the throttle on the audi 2.4i
I do not know how to connect it.
I enclose a scheme throttle
Thank you
Sorry for the bad english (google translate)
Doofy
Re: TPS and Stepper motor. Audi
Post by Doofy » Wed May 13, 2015 1:28 pm
more img
Post by Jadzwin » Wed May 13, 2015 1:41 pm
EMU doesn't support this kind of the idle control. So you need to use eg. PWM valve or install full electronic throttle.
Doofy
Post by Doofy » Wed May 13, 2015 1:48 pm
Can tell me how to implement the idling?
Horsty
Post by Horsty » Wed May 13, 2015 3:39 pm
you can use for the aan the original throttle body and tps with the external idle valve.
or you go for the passat, a6, a8 electronic gas pedal and a full electronic throttle body.
SSP_210 elektronisches gas pedal.pdf
(1.69MiB)Downloaded 120 times
Post by Jadzwin » Wed May 13, 2015 4:26 pm
In AAN there should be idle valve like this:
Doofy
Post by Doofy » Thu May 14, 2015 8:03 am
Thanks!
Doofy
Post by Doofy » Thu May 14, 2015 8:05 am
Using VEMS I could not achieve the correct operation of the valve of idling.
Welshman
Post by Welshman » Thu May 14, 2015 11:34 pm
i have bought that idle valve you pictured Jadzwin , what are the settings for one of those ?
