Celica ST205 Gt Four
astra vxr
Re: Celica ST205 Gt Four
Post by astra vxr » Wed Feb 11, 2015 7:43 pm
pipe work problem then :)
pepifebles
Post by pepifebles » Wed Feb 11, 2015 7:53 pm
astra vxr wrote:pipe work problem then :)
yes. Could I take oem map hose? Oem will be disconnected.
The fun starts now
Post by Jadzwin » Wed Feb 11, 2015 8:10 pm
Yes it will work ok :)
Your car the should work as factory one :)
pepifebles
Post by pepifebles » Thu Feb 12, 2015 6:43 pm
Solved. New hose directly to intake manifold and run perfect.
In the other hand, when I received maps by mail to my mapper. How to write it in the ecu?
The fun starts now
Post by Jadzwin » Thu Feb 12, 2015 6:55 pm
You just need to use option Load project and then makes map permanent (F2 key).
However remote mapping is not the best solution
pepifebles
Post by pepifebles » Thu Feb 12, 2015 7:04 pm
Its the only one solution possible for me.
Then, engine start or ignition on? Open project and F2
The fun starts now
astra vxr
Post by astra vxr » Thu Feb 12, 2015 8:56 pm
i would have used the base map you have ( it dont look to bad ) and map from there even if you have a map sent to you it could be still off and still need mapping as no 2 engines are the same but each to there own
pepifebles
Post by pepifebles » Fri Feb 13, 2015 1:58 pm
astra vxr wrote:i would have used the base map you have ( it dont look to bad ) and map from there even if you have a map sent to you it could be still off and still need mapping as no 2 engines are the same but each to there own
Yes, mapper have used base map and on this have change parameters. He sends me modified maps and I run it, log and tell him my impressions. Isnt easy but its possible
The fun starts now
pepifebles
Post by pepifebles » Tue Feb 17, 2015 9:24 pm
My Engine originally runs watercooler. Watercooler Pump is controlled to oem ECU, and now I think that emu dont controller Good. Easy to see high IAT tenperature. There is Any option to run watercooler Pump with my new emu.
Regards
The fun starts now
Jan32
Post by Jan32 » Wed Feb 18, 2015 9:51 pm
If everything is right connected and you use the base map from Kuba for your engine, then the water pump is activated everxtime when the motor runs. Look at Parameter output 3 at the settings there is the output activated when rpm is higher than 600 rpm.
pepifebles
Post by pepifebles » Fri May 22, 2015 9:57 pm
hi guys,
after three months of hard work, today I was able to dust off my car and continue configuration of my Emu Ecu . It is impossible to run well, I must have a problem with the map sensor because the idling its unstable, at iddle when I acceleratethe engine stop, just blowing 0.7 bar ( wastegaste pressure ), the mixture is very lean (1.25 to idle). This problem occur's with all maps (base map and other 2 maps).
Does anyone have any idea what happens ?
When I load base map, This error occurs, and when load my maps, this message it´s too much longer
The fun starts now
pepifebles
Post by pepifebles » Sat May 23, 2015 9:00 pm
upload video to show my problems
View My Video
The fun starts now
Post by Jadzwin » Sun May 24, 2015 12:01 am
Ignore this message. It is just warning. Different software versions have different tables / parameters.
pepifebles
Post by pepifebles » Tue May 26, 2015 7:44 pm
I reconnected the original ECU and the engine run fine, perfect. I connect the emu as I ever have all kinds of failures ( video above ) . Could this be mapping problem?
Regards
The fun starts now
Post by Jadzwin » Tue May 26, 2015 9:51 pm
Send the log file. We will see what is going on. Should work normally if everything is ok
pepifebles
Post by pepifebles » Tue May 26, 2015 10:10 pm
How to rec log file? Only know see it.
The fun starts now
Post by Jadzwin » Tue May 26, 2015 10:19 pm
Just press disc icon on the log window toolbar. The file will contain all channels so just press the icon.
pepifebles
Post by pepifebles » Sat May 30, 2015 6:48 pm
Finally all runs ok but I dont get boost. I upload my log and my map
Prueba Boost 01.emu
Map
(78.39KiB)Downloaded 100 times
mapa prueba boost1 soplado.csv
Log
(20.34KiB)Downloaded 79 times
The fun starts now
