Question about CAN feature.
sulik
Post by sulik » Sat May 16, 2015 9:52 am
Hello guys,
i have a question about the CAN features of the EMU.
Maybe some of you guys know that the germany TUV is one (if not the strongest) car checking company in the EU. :x
Here in germany we have massive problems with our exhaust noise limitations.
For the VW Golf, Audi etc. people there are boxes out there which can control exhaust flaps/valves for nois restrictions like:
-car idles -> flap is closed
-car drives over 70km/h and over 50% throttle body flap is open = free flow exhaust + noise 8-)
The problem for us old car drivers is that these boxes will only work with CANbus.
So is it possible to use such a unit with the EMU?
Can the EMU "emulate" CANbus or send the same signals like RPM, % of TB, boost etc. or something like that?
Thanks for your help. :)
roquete
Re: Question about CAN feature.
Post by roquete » Sat May 16, 2015 5:05 pm
You dont need Canbus for that, EMU can control a flap valve directly, using one aux output set to whatever rpm or tps you would like.
Racekid21
Post by Racekid21 » Mon May 18, 2015 8:28 pm
Um was für eine Klappe handelt es sich denn?
Gruß
sulik
Post by sulik » Tue May 19, 2015 9:15 am
@roquete
That would be perfect! :)
@Racekid21
Die von HG-Motorsport z.B.
Wenn die EMU das allerdings selber ansteuern kann (mit einem solenoid dazwischen9 dann ist es auch gut.
Wieder mehrere hundert € gespart. 8-)
Racekid21
Post by Racekid21 » Sun May 24, 2015 4:30 pm
Das kann die Emu definitiv.
Setz dich am Besten mal mit Boba in Verbindung- der hat eine Klappe am laufen. Denke er kann dir da gut weiterhelfen.
Gruß
Post by PSI-Motor » Mon May 25, 2015 11:48 pm
English please.
sulik
Post by sulik » Sun Jun 07, 2015 1:55 pm
We talkned about an exhaust flap from a company called HG-Motorsport in germany.
It works with CAN-bus signals.
Racekid21 wrote that the EMU does work with a solenoid in the vacuum line which goes to the flap.
And i should contact Boba motoring, because i he runs the flap/ solenoid with the EMU.
