Mitsubishi evo v rs base map
Gsxrmel
Post by Gsxrmel » Thu Jun 04, 2015 11:25 pm
Hi ,where i can find a evo v base map? For stock car
Thanks a lot
Regards
Re: Mitsubishi evo v rs base map
Post by Jadzwin » Fri Jun 05, 2015 9:33 pm
Please find attached EVO base map.
IMPORTANT: For EVO coils you need to use 2K resistor in series between EMU ign output and the coils! Otherwise the coils could blow up.
evo startup.emu
(75.96KiB)Downloaded 140 times
roquete
Post by roquete » Sat Jun 06, 2015 10:08 pm
Jadzwin wrote:Please find attached EVO base map.
is the resistor needed for evo3 too ?
Post by Jadzwin » Mon Jun 08, 2015 11:06 am
In EVO3 you can connect coils directly to EMU (without ignition module) so no resistors are required But you must before connecting coils change ignition output type from coils with built in amplifer to coils without amplifier. Otherwise you destroy the coils!
roquete
Post by roquete » Tue Jun 09, 2015 1:40 am
Tanks for the info, will be using the module as it reliefs stress from the ecu and also it has output already connected to tach.
TME
Post by TME » Thu Jun 11, 2015 4:18 pm
Hello all
I´m also new in EMU World, and I have some questions for "advanced" users...:
- my Evo6 TME, has AYC. How EMU can manage th YAC if there isn´t any pin for it? (or at least, not in the pinout)
- I followed the pinout for evo and the "jumpers" described for my model. However, car does not start, and Fan works in High mode
I took: R6, R10, R12 and R14
some help from you will be appreciated.
thanks!
