Intel OpenGL driver
Intel OpenGL driver
Post by Jadzwin » Thu Mar 12, 2015 1:15 pm
If you have problems with 3D tables/ Gauges display or crash of EMU client, it is caused by bggy Intel Open GL driver.
For all people that own computers with integrated Intel graphics card here is a solution.
Originally posted by Wuniek
ok i managed to manual install driver from Intel web site : https://downloadcenter.intel.com/downlo ... 8-1-64-bit
conclusion is that on driver version 10.18.19.3308 EMU client have problems with OpenGL library :
the problem seems to be absent in the latest version of the driver 10.18.10.3958 :
it is to late for me to check it but i think new driver have updated version of OpenGL 1.2
Wuniek
Re: Intel OpenGL driver
Post by Wuniek » Thu Mar 12, 2015 1:51 pm
working driver LINK : https://downloadcenter.intel.com/downlo ... 8-1-64-bit
and manual how to install driver ( its needed when you finish normal setup with info like "contact your hardware manufacturer for proper driver" ) : http://www.intel.com/support/graphics/sb/CS-033916.htm
clem
Post by clem » Sat Mar 14, 2015 11:02 am
as I had Problems with my driver (no win 8.1 support for my old machine) I downgraded to windows 7 and tryed the driver form your link. But now I get the same error report when I try to install the driver: Hardware does not match with the driver.
Also I tryed different drivers, e.g. from the asus support page, but they do not seem to work with the emu client. Although the client does not crash anymore when I open gauges or 3d tables, they are simply not displayed (3d table displays only the left half of the window)
:shock: :cry:
My device manager says I have an Intel GMA 3150 Graphic chipset. Machine is an ASUS eee 1215n from the late 2010 year.
Buy a new(er) computer would be the last thing I would want to do...
Clem
Wuniek
Post by Wuniek » Sat Mar 14, 2015 11:55 am
Hi clem,
what kind of windows are you using 32 or 64 bit ? https://www-ssl.intel.com/content/www/u ... =Downloads
the whole "trick" of manual install is to chose option "Have Disk..." and point location of files, when you once install driver manually next time you start windows you will can start normal setup.exe from intel driver package to add Intel Graphic Option control panel
if you have further problems with driver i suggest try to look driver via Vendor and Device Lists : http://www.makeuseof.com/tag/how-to-fin ... device-id/
clem
Post by clem » Sun Mar 15, 2015 9:56 am
Hello Wuniek - IT WORKS
Big thanks!!! One thing I miss in your description was, that search manually on the computer for software has to be selected twice to get to the "have disk" button.
I had to try several times until I finally found the window from your picture.
Awesome Help dudes :)
Thank you!
killerbee
Post by killerbee » Sun Mar 22, 2015 10:37 am
My laptop is with Mobile intel (r) 4 series express chipset family , windows 7 ultimate 32 bit , I try with 4-5 drivers no luck still EMU software crash on opening 3d tables ( fuel , ignition , afr target ) ...
EDITED - it worked with this https://downloadcenter.intel.com/downlo ... Vista-zip-
samvel
Post by samvel » Thu May 07, 2015 7:34 pm
Which driver should i download/install for 7-64 ?
I have 4 Series Express Chipset Family, driver version 8.15.11.8688
nemitom
Post by nemitom » Wed Jun 10, 2015 12:02 am
Please consult the driver for me. Dell XT2 with W7 64bit.
My graphics card is a Mobile Intel (R) 4 Series Express Chipset Family (ven_8086 dev_2A42)
I tried almost all versions, but unfortunately. The only driver that works (not full) is original from W7 ver. 8.15.10.1749 (WDDM 1.1)
driver version 8.15.11.8688 not find, please sent link
Wuniek
Post by Wuniek » Wed Jun 10, 2015 9:10 am
did you tried 15.17.19.64.2869 (8.15.10.2869) ?
https://downloadcenter.intel.com/downlo ... ta-64-zip-
did you tried manual install of drivers instead using setup.exe ?
PS.ven_8086 dev_2A42 is G45 Intel chip ( https://downloadcenter.intel.com/produc ... ss-Chipset )
nemitom
Post by nemitom » Wed Jun 10, 2015 12:54 pm
yes I used the manual installation.
But without success. Not working.
Gauges are now in order. (Background)
Thank you for your help
edit:
8.15.10.1749 - work and bug (Windows 7 orig. drivers)
8.15.10.2302 - not work
8.15.10.2869 - not work
can not be error somewhere else?
W7 drivers
Wuniek
Post by Wuniek » Thu Jun 11, 2015 12:41 am
Intel GPU drivers signed by vendors is total magic, last question is what version of software you are using ?
- official http://ecumaster.com/en/download
- test version http://www.ecumaster.com/testVersions.html
- something between above
nemitom
Post by nemitom » Thu Jun 11, 2015 1:07 pm
Im tested
orig W7 driver
viewtopic.php?f=19&t=3&start=326
Wuniek
Post by Wuniek » Fri Jun 12, 2015 8:34 am
really? version 1.000 and 1.113?
try to install latest official 1.1 and later test version 1.130 EXP 2, there was few changes after official 1.0 in client display method
nemitom wrote:Im tested
orig W7 driver
nemitom
Post by nemitom » Fri Jun 12, 2015 3:26 pm
yes really!
version 1.100 is full worked on Windows 7 driver.... new beta 1.300 not work....
Wuniek
Post by Wuniek » Fri Jun 12, 2015 4:33 pm
official version is working thats good :)
in the test version you can try play with graphics options maybe it will somehow help you:
nemitom wrote:yes really!
nemitom
Post by nemitom » Fri Jun 12, 2015 4:47 pm
change options does not help...
I would like the latest version of the functional :oops:
Wuniek
Post by Wuniek » Fri Jun 12, 2015 5:03 pm
post issue with latest version in "Bugs and Feature reqests", I`m not from support and i cannot help you any more :(
last thing i have in mind is to play with graphic acceleration setup https://www.youtube.com/watch?v=8U-um6nfcKU
but it is Intel GPU that means that can be never ending story...
nemitom wrote:change options does not help...
Post by Jadzwin » Fri Jun 12, 2015 7:36 pm
We made some improvements to speed up gauges drawing. Please contact me at info@ecumaster.com and we can make a session to check what is the problem on your computer.
Swift turbo
Post by Swift turbo » Mon Dec 14, 2015 2:35 pm
Hi ...I have a Toshiba Satellite C660 with Intel HD graphics on board.I am using EMU Client 1.157EXP 1...I am only able to run the EMU client in a "sandbox" and it does not appear possible to update the Intel HD driver.I cannot run 3d tables or gauges
I have tried manual installs of all possible Intel drivers and Toshiba only list the current driver I have installed and this goes back to 2010! Is there an alternative to buying a new laptop? There is a BIOS update available from Toshiba but I'm not sure it will solve the problem.Your ideas would be appreciated.Thanks..
Swift turbo
Post by Swift turbo » Sun Jan 10, 2016 4:35 pm
After many different file downloads and aborted installs I finally found one that my Toshiba laptop will allow me to install in place of of my existing driver..It became apparent to me that you don't go for the" latest" driver but look for the next updated driver in date order to the one you have installed.This is the one that worked for me.... Intel® HD Graphics Driver for Windows Vista* and Windows 7*Version: 8.15.10.2622 Its an .exe file rather than a zip file but still installed ok .Building the plug and play adapter now!
