3sgte Rev 3 High IAT
pepifebles
Post by pepifebles » Wed Jun 24, 2015 10:38 pm
Is it normal for the iat is fired so fast? Just accelerated 3 or 4 times to full boost (1,3bar/1,4bar) and the temperature reaches 70 degrees. I understood that the original 3sgte Rev 3 watercooler supported over 350 hp.
My exhaust system is 3" but I recently changed a stretch (about 1 meter) and I've put a universal catalyst in a 2,2" tube to approve ITV/TUV. How will this influence?
I`ve attached cold and hot log.
Base_1 caliente.emulog
Hot Log
(86.39KiB)Downloaded 98 times
Base_1.emulog
Cold Log
(46.75KiB)Downloaded 100 times
The fun starts now
skogs
Re: 3sgte Rev 3 High IAT
Post by skogs » Wed Jun 24, 2015 10:50 pm
Isnt 1.4 Bar a bit much for the stock turbo? And why are your boost levels so uneven? It looks like it fluctuates like crazy.
pepifebles
Post by pepifebles » Wed Jun 24, 2015 11:03 pm
skogs wrote:Isnt 1.4 Bar a bit much for the stock turbo? And why are your boost levels so uneven? It looks like it fluctuates like crazy.
Its turbotechnics s148-3 ;). this is the problem, fluctuation are caused by IAT corrections. I dont know if oem watercooler its enough
The fun starts now
ATS_Scott
Post by ATS_Scott » Thu Jun 25, 2015 1:41 am
I don't see any IAT corrections in your log (may have missed it), but I do see Boost duty dropping out from boost PID error correction. It seems you are relying too heavily on the PID correction, and it is adding 15% DC until it overshoots target boost, where it seems to overcorrect. I would turn PID correction off, and get boost dialed in in open loop first, then the closed loop control is not working so hard.
I'm assuming you are using the ST205 MAT sensor as IAT, and the stock ST205 intercooler? If so, I think you are just heat soaking the system, it does not have much of a reservoir. If you are not, you will want to run the intercooler waterpump almost constantly, and make sure you have good fans on the IC radiator. then add a reservoir if you can find the room.
pepifebles
Post by pepifebles » Thu Jun 25, 2015 9:42 am
True. In this map havent IAT correction because dont modify this table. In other maps when iat reach 60/70º begin to do corrections 95%/90%.......
I try use first open loop. I dont understand very good cloose loop, PID, etc and think that for this reason don't get boost under 4000rpm.
I use stock IAT sensor and stock intercooler. My car its celica ST205 then I havent IC fans. How to do intercooler waterpump runs constantly? Can I do by Emu?
The fun starts now
SUKHOI
Post by SUKHOI » Thu Jun 25, 2015 10:49 am
I have done same engine before on another ECU, as we live in relatively hot weather country, after few pulls the IAT reading reach to 80c-90c, the best I found to convert it into front mount cooler, and everything after it were great.
pepifebles
Post by pepifebles » Thu Jun 25, 2015 11:01 am
Do you eliminate complete stock system or only changed front radiator?
What size advise me? I'm from Canary Island.
The fun starts now
SUKHOI
Post by SUKHOI » Thu Jun 25, 2015 12:09 pm
Here we removed the stock intercooler and put aftermarket china front mount intercooler, the IAT dropped significantly.
pepifebles
Post by pepifebles » Thu Jun 25, 2015 7:36 pm
What pipe diameter use? Seems 3". Do you have lag?
The fun starts now
Post by PSI-Motor » Thu Jun 25, 2015 8:42 pm
You don't get more lag just by going up in Intercooler and piping size, thats a bit of a myth :)
I have tested this in the dyno :)
pepifebles
Post by pepifebles » Thu Jun 25, 2015 9:42 pm
ok, then what is the advantage/disadvantage to change bigger pipe size?
The fun starts now
SUKHOI
Post by SUKHOI » Thu Jun 25, 2015 11:21 pm
If you are so worried about lag and such things, you can do the pipes from turbo to intercooler in the size of the turbo outlet, and from intercooler to throttle in the size of throttle, the issue here that I didn't like the stock design of putting the intercooler straight above the engine, specially that the exhaust manifold is not that far as well from the intercooler, so a front mount intercooler well get the fresh cold air and do pretty good job in lowering IAT readings, as there was no noticeable loss in boost or extra lag as well from using 60mm from turbo and 76mm to throttle.
pepifebles
Post by pepifebles » Thu Jun 25, 2015 11:54 pm
Ok. Will be enough 560mm x 180 mm x 57mm intercooler? or better standard 600 x 300 x 76?
The fun starts now
SUKHOI
Post by SUKHOI » Fri Jun 26, 2015 12:53 am
I would go with biggest could fit
ATS_Scott
Post by ATS_Scott » Fri Jun 26, 2015 7:35 am
PSI-Motor wrote:You don't get more lag just by going up in Intercooler and piping size, thats a bit of a myth :)
Agreed! If anything you might pick up a little response with better flowing pipes and intercooler. You will definetly gain from cooler IAT.
pepifebles
Post by pepifebles » Sat Jun 27, 2015 3:10 pm
I think that have problem with intercooler water pump. It isnt normal that 1,1bar reach 95c. Please see 2 logs attached, first log its long pull 4º gear, 1,1 bar and 95c. Second log drive normally 100km/h to low rpm and low boost and IAT dont decrease too.
How can check if my Intercooler water pump works?
MBB 3 subiendo pista.emulog
Log pull
(24.08KiB)Downloaded 93 times
MBB 3 T alta tranquilo.emulog
Log low rpm
(126.21KiB)Downloaded 97 times
The fun starts now
Welshman
Post by Welshman » Sat Jun 27, 2015 3:38 pm
open the charge cooler cap , blip the throttle the water should swirl , if its running constant it should be swirling all the time , if its still the pump isnt working
what are your calibration settings for the stock toyota senser , i use the same and the "correct " values would be handy ?
these are my IAT settings
pepifebles
Post by pepifebles » Sat Jun 27, 2015 5:43 pm
Welshman wrote:open the charge cooler cap , blip the throttle the water should swirl , if its running constant it should be swirling all the time , if its still the pump isnt working
Mine is different but not enough to reach 90c. I dont modified this calibration to base map.
The fun starts now
Welshman
Post by Welshman » Sat Jun 27, 2015 5:53 pm
did you check if your pump is working ? only takes a second ..
pepifebles
Post by pepifebles » Sat Jun 27, 2015 6:10 pm
I just do it and bad news :( . The water does not move or have swirls. In addition, a very rare thing is that the intercooler water reservoir is full of water
The fun starts now
