opel/vauxhal C20Xe configuration
Botasjr
Post by Botasjr » Mon Jun 29, 2015 8:46 pm
hi
i present my self, because is my first time on this forum, i have tuned some emu and det ecus, but i never have installed any, and now im starting with an EMU ecu on my small racing car, if i post a photo you can call me crazy...
my name is Andre Pires, and i have a small tuing company in portugal, i have a big experience on megasquirts since 2007, i have dyno, afr, knock etc, the essencial, and now i need something more,
im installing an emu on a c20xe engine
original engine, orignal, injectors, original wasted spark ignition coil (bosch 3 wires), throttle etc,
my big questions are about the
- primary trigguer configuration on the software
- injectors configuration / firing order
the engine runs on 1-3-4-2
on the ecu plugs i have
4 injectors wires G-1 G-15 G-23 and G-6
2 ignition drivers G-8 and G-16
primary trigguer on B-7 (+) B-18 (-) and B-24 (shield), i dont use the cam trigguer.
and all other are normal
i know that those engines have a 60-2 crank wheel, and im not really sure, but the crank sensor alligns at theet nº19 when the 1st cylinder is at TDC, i always check this with strobo light.
someone can help me with this???
regards
astra vxr
Re: opel/vauxhal C20Xe configuration
Post by astra vxr » Mon Jun 29, 2015 11:21 pm
its not a lot differnt to megasquirt :) been useing m/s for 10 years and switched to emu now
i have basic settings some where ill dig them out for you what coil pack are you useing ? gen xe one or later ecotek one ?
10deg before tdc is tooth 9
or
114 deg
injectors will be your fireing order or you can go more forward 1,3,4,2 or 3,4,2,1
coil will be same as megasquirt to fire one bank and then the other
ill dig out my settings one i get home :)
Botasjr
Post by Botasjr » Tue Jun 30, 2015 9:41 am
there is some photos of my instalation
like you can see the original ignition bosch coil
is this a good coil???
http://fotos.sapo.pt/xpower/fotos/?uid= ... H3uC4r3cGY
http://fotos.sapo.pt/xpower/fotos/?uid= ... cI9K6PvEiZ
http://fotos.sapo.pt/xpower/fotos/?uid= ... VTk3tEzIWy
http://fotos.sapo.pt/xpower/fotos/?uid= ... vC3zBz9y7z
sorry but i cant post the photos like as image, please see on the browser.
regards
Botasjr
Post by Botasjr » Tue Jul 07, 2015 9:40 pm
im having very strange problem on cranking
im just testing the crank vr sensor input, i dont have any coil or injector connected,
sometimes i get the aprox. 200 cranking rpms
and some other times i dont get nothing,
someone can help me???
clamp
Post by clamp » Tue Jul 07, 2015 10:53 pm
maybe your crankshaft sensor is broken!
p.s about the pictures what is right configuration for this camshaft sensor ? and why you don`t use camshaft sensor?
Botasjr
Post by Botasjr » Tue Jul 07, 2015 11:05 pm
with the digital multimeter i only get 1.5 volts / AC
is this a good value???
i dont use the camshaft to simplify the conections, for now...
im trying to set a wasted spark configuration.
Botasjr
Post by Botasjr » Thu Jul 16, 2015 8:49 pm
ok
after a few days,
i got the engine runing, at the first start, good....
yesterday i have tuned the engine on the dyno, everithing is good till 6500 rpm,
above 6500 rpm the engine revs very bad, it seems that have a spark cut rev limiter, it seems that have spark retard, but i have checked with the strobo light on the dyno and i dont have any ignition timimg movement.
i thing is an ignition components problem, because, first we are using old spark plugs, and the problem appear at 5800 rpm, with new spark plugs the problem rise to 6500 rpm.
i read somewere about the original xe ignition coil problem, is that correct???
you can see the configuration and a log attached.
and a video here:
https://www.youtube.com/watch?v=DdVMGGchSB4
log.emulog
(595.12KiB)Downloaded 107 times
20150715_1544_09.emu
(77.88KiB)Downloaded 142 times
4takter
Post by 4takter » Thu Jul 16, 2015 9:03 pm
34° Ignition at WOT will kill this Engine. Have you noticed signs of Detonation?
Best Regards
Frank
Botasjr
Post by Botasjr » Thu Jul 16, 2015 9:14 pm
4takter wrote:34° Ignition at WOT will kill this Engine. Have you noticed signs of Detonation?
are you sure????
i see 24
and with the strobo light shows me very near of a 25º that i have on the puley.
and with the knok phones i can ear any sign of detonation.
Botasjr
Post by Botasjr » Thu Jul 16, 2015 9:16 pm
now i see one thing that i maybe need to test, i dont know,
i have rising edge on the primary trigguer
could this affect the engine?
Post by PSI-Motor » Thu Jul 16, 2015 9:49 pm
Botasjr wrote:now i see one thing that i maybe need to test, i dont know,
Use scope function to se wich you should use.
4takter
Post by 4takter » Thu Jul 16, 2015 10:22 pm
Sorry, you are right 25 at WOT. I had a look in the wrong column. (to much ecu Brands at the moment ;) )
Best Regards
Frank
HVR Team
Post by HVR Team » Fri Jul 17, 2015 6:29 pm
Hello
Which crank sensor is in use, had the same problem with the Bosch sensor, I replaced it with Hella Sensor, operates at 9000 rpm with no problems
Botasjr
Post by Botasjr » Fri Jul 17, 2015 7:20 pm
Hello
im using a brand new original bosch sensor
astra vxr
Post by astra vxr » Fri Jul 17, 2015 9:09 pm
the coil pack new ???
we use the ecotec coil pack and that does the same thing when its getting old and we run 3 bar of boost on one of these coil packs up to 8200
but the sensors are known for it after 6.5k hall sensors are better over vr ones but if its a new sensor and its wired correct then it should be a problem we have had a vr to 9.5k with out problems a few years ago on megasquirt :)
astra vxr
Post by astra vxr » Fri Jul 17, 2015 9:14 pm
are you useing map sensor ?? going buy the settings you are and the log is showing 100kpa all the time
Botasjr
Post by Botasjr » Sat Jul 18, 2015 9:53 am
astra vxr wrote:are you useing map sensor ?? going buy the settings you are and the log is showing 100kpa all the time
no im using the alpha-n
on that configuration file, the barometric correction is no "on", for now...
Botasjr
Post by Botasjr » Sat Jul 18, 2015 9:58 am
astra vxr wrote:the coil pack new ???
i dont thing this is a vr sensor problem, because i dont lose crank signal, all the rev range.
im thinking to install a 032 905 106B vag coil, i use them on others install with success,
this coil have a built in driver.
do you have a picture of this ecotec coil??? or reference???
regards
astra vxr
Post by astra vxr » Sun Jul 19, 2015 2:16 pm
this one is what we used to use :)
HVR Team
Post by HVR Team » Mon Jul 20, 2015 8:53 am
regards
Hello
According to log, is looks that the engine goes into the speed limiter(Fuel cut), set you at 7300 rpm, then everything is ok, works as you have set :)
