1uzfe wiring problem
hello everybody!
i just wired up an 1uzfe to the emu but i am not getting a crank or cam signal. i did the 2k2 resistor on the 5v circuit to the signal side of the sensor.
anyone any thought?
anyone any thought?
Re: 1uzfe wiring problem
Why the extra resistor ?lucasc wrote:hello everybody!
anyone any thought?
Is not 1UZ using normal magnetic sensor on crank ?
i have tried without and changed the settings accordingly.
does anybody have a wiring schematic for a 1uzfe?
wirring schematics? For what ? You mean OEM wirring ?
put the mag sensor on pin for sensor ground and primary trigger, cam sensor on secondary trigger, TPS one on sensor ground, second on TPS input and the third to +5V, conntect your injectors on one side to switched 12V and the other end on EMU outputs for injectors etc..............
So what do you need ? It easy, liek every other engine
i did that.... this is why i came tot he forum for help! i have tried switching wires for signal to ground and vica versa... no result.
i know it should be dead easy but somehow i am missing something.
checked the sensors and they are still good on the bench
did you solve the problem ?
- Kisielisodd
- ECUMASTER TEAM
http://lmgtfy.com/?q=1uzfe+wiring+diagramlucasc wrote: does anybody have a wiring schematic for a 1uzfe?
first link
no problem is still there unfortunatly.
Please write an email to tech@ecumaster.com
Im now solving almost the same problem ( custom wiring, shielded ) but no crankshaft signal, and no camsfaht signal ( Im using cam on the drivers side ).
Can you please wrote what was teh problem? maybe I have the same ( 1UZ FE 89 - UCF10 ).
