vr6 turbo launch control
DET3 technical support
b3nj4m1n
Post by b3nj4m1n » Fri Oct 02, 2015 1:38 am
Finally got my vr6 turbo running on the det i had the crank signal wires wrong way round now im taking it in to be mapped next week and want to put everything in ready can some please explain pullup resistors and where can i get 1 from as i wish to run launch control thanks
ihiryu
Re: vr6 turbo launch control
Post by ihiryu » Fri Oct 02, 2015 6:29 pm
How are you running your launch control? Do you plan to run it via Freq IN?
If so, I don't think you even need a pull up. Just select Freq In, and click invert. And wire Freq In to a ground source (I have it done to my clutch switch), and it should work fine.
