Hopefully someone can offer advice on this
i currently use a MAC PWM solenoid to control the upper area of the wastegate,
the EMU currently controls this with a DC / RPM table with a maximum boost being reached at 80% (220 KPA). This works very well but the bike is slow to build boost after a gearchange as i have the solenoid at 80 %.
Engine rpm is 10800 before the shift and 9500 after so this should not be a limiting factor.
would i be better switching to the target boost table with PID contol in this way i can request 220 KPA and the solenoid should react accordingly and try to achieve target regardless of engine speed ? and can anyone suggest starting values for the PID loop.
or is there a better way ?
