hi:)
i need help about proper configuration and wiring for this sensors.
C20XE m2.5 crankshaft i think is VR sensor?
C20xe m2.8 camshaft is VR again?
and what is wiring configuration?
Can i use my fuel tank ventilation valve? and where i can connect and setup?
C20XE crankshaft,camshaft and Evap
Re: C20XE crankshaft,camshaft and Evap
crankshaft is
1pin + B7
2pin - B18
3pin shild B18
its true ?
1pin + B7
2pin - B18
3pin shild B18
its true ?
Hello
Yes the Crankshaft sensor is VR,but the Camshaft sensor, if Motronic 2.8 is Hall and need 12v+
Wiring Crankshaft sensor VR: Pin 1=B7,Pin 2=B18,Pin 3 Shield=B17
Wiring Camshaft sensor M2.8 Hall: Pin 1=12v+across the fuse,Pin 2=B15,Pin 3 Shield=B17
thx this information is very helpful.
do you have idea about fuel tank ventilation valve? can i use my oem valve?
You can use it using parametric ouptut
