Full pull BMW Turbo 550hp.
Post by PSI-Motor » Sat Oct 31, 2015 11:44 pm
I recorded some pulls in the dyno this evening and wanted to share my desktop setup when im tuning.
Notice lambda vs lambda target :)
https://m.youtube.com/watch?feature=you ... R00ZECoo0g
Re: Full pull BMW Turbo 550hp.
Post by RHD » Sun Nov 01, 2015 4:45 pm
yes very nice!!
jbrito
Post by jbrito » Sun Nov 01, 2015 5:20 pm
Very nice Man,
What BMW is? 325?
Post by PSI-Motor » Sun Nov 01, 2015 8:07 pm
jbrito wrote:Very nice Man,
What BMW is? 325?
You are correct sir :)
Welshman
Post by Welshman » Mon Nov 02, 2015 3:21 am
i noticed your map line is very smooth compared to mine , are you using the inbuilt map sensor ? im thinking of changing my map sensor so i can have a shorter pipe to get a smoother reading .
Post by PSI-Motor » Mon Nov 02, 2015 6:00 am
Welshman wrote:i noticed your map line is very smooth compared to mine , are you using the inbuilt map sensor ? im thinking of changing my map sensor so i can have a shorter pipe to get a smoother reading .
Hi Welshman.
Im always using the EMU map sensor.
Go in under sensor setup and tick the box "mapsensor filter" and just use level 3.
Post by RHD » Tue Nov 10, 2015 9:01 am
Hi would you care to share what sort of values you use for the charge temp table? and/or how you go about selecting them?
