importance of dwell correction vs rpm ? if any ..
Welshman
Post by Welshman » Wed Dec 30, 2015 5:31 pm
ive been having spark blowout trouble on my gen4 3sgte , while scanning the map i noticed the dwell correction on on a ramp down to 80% by 8k from 500 ( 500 = only point at 100% )
i changed this to 100% all through and now with 2.7ms dwell in logs im running fine up to 8k @ 1.8 bar ( hopefully a good 550+hp at this )
i just wondered is there any reason this setting should be there or am i fine as i am ?
ATS_Scott
Re: importance of dwell correction vs rpm ? if any ..
Post by ATS_Scott » Thu Dec 31, 2015 1:37 am
Welshman wrote:ive been having spark blowout trouble on my gen4 3sgte , while scanning the map i noticed the dwell correction on on a ramp down to 80% by 8k from 500 ( 500 = only point at 100% )
I'm running the same dwell with no RPM correction on my GEN4's, but only running 400HP at wheels with billet compressor on otherwise stock CT15.
Welshman
Post by Welshman » Thu Dec 31, 2015 7:06 pm
that will do for me , i dont remember setting it , maybe the wizard did it if i clicked on a coil set sometime .
Post by Jadzwin » Mon Jan 04, 2016 1:39 pm
We commonly use the following correction. It could improve idle speed (less misfires due to higher spark energy) and due to low effective DC it doesn't influence the coild temperature / life.
flubyux2
Post by flubyux2 » Fri Mar 25, 2016 7:22 am
im also having spark blow out over 18psi with my 1jzgte but before switching to EMU, I was able to run 21psi smoothly. also using a conservative 0.025" plug gap.
the coil dwell corr table is untouched from the original 2jzgte base map I began with.
I did try to increase the coil dwell time table under the normal operating voltage regions but afraid to make large changes because I don't want to overheat the coils.
Welshman
Post by Welshman » Fri Mar 25, 2016 12:48 pm
mine improved once i put the dwell correction to 100 .
if you look a your logs it will tell you the actual dwell when its running .
flubyux2
Post by flubyux2 » Wed Apr 13, 2016 4:03 am
today, i finally went into my emu and changed my dwell correction to 100% on the last cells. so far, so good. no spark blowout yet at low boost. i have to take the car out under high boost in cooler weather and see if my issue is solved.
if a little dwell correction fixed my low boost problem, i wonder how much the % can be safely increased to combat the spark blowout under much higher boost conditions without damaging the coil packs. i would hate to melt them down or overdrive them.
