C20XE idle control valve propper configuration
clamp
Post by clamp » Sat Jan 23, 2016 4:18 pm
hi ,
i have problem with propper configuration with this idle valve . My car is C20Xe turbo but i have high idle and unstable. I use 72mm throttle body.
my idle target rpm is 1100 but my idle is 1200-1300. this idle control valve have reaction only with idle ref table !
p.s i upload my Log with start, cranking and idle test
start+idle.emulog
(759.98KiB)Downloaded 116 times
Re: C20XE idle control valve propper configuration
Post by PSI-Motor » Sun Jan 24, 2016 12:34 am
You have to tune idle ref before activating PID.
Many people sometimes blame the idlevalve when its actually the ignition table and fueltable thats the problem.
Post by RHD » Tue Jan 26, 2016 12:42 pm
also find what frequency is correct for your valve... many bosch idle valve need about 100Hz
clamp
Post by clamp » Tue Jan 26, 2016 8:07 pm
i try with 100 with 60 but idle valve is more unstable
derOJ
Post by derOJ » Sat Jan 30, 2016 4:56 pm
Did you install a flyback diode?
clamp
Post by clamp » Sun Jan 31, 2016 1:54 am
yes but this flyback diode is for other things.
today i see new .. my idle max parametar was set to 2500rpm when i set to 1500 my idle from 1300rpm was icrease to 2100 rpm..(with this settings)
tomorrow i will try new settings with max idle 1500rpm
