i have problems with my EGT setup.
i use two controller , one from emu and one external controller.
in Idle ich have around 370degrees (external controller)
and emu i have only 170 degrees ..
can i change the ref. table from egt? and where is the option? i cant find it
or i must work with Pullup resistor?
greetz
EGT calibration
Re: EGT calibration
The EMU is compatible with K-Type thermocouple. The voltage produced by this type of sensor is strictly defined so no calibration is required.
Re: EGT calibration
Thanks!!
Problem is solved ,the sensor was broken
