bluetooth problem
mmt
bluetooth problem
Post by mmt » Thu Jun 18, 2015 12:33 pm
I use your great app,with mob samsung S6 work well. This weak I bought 7inch Android 4.4.4 2din unit for my BMW E46 M3. It's multifunctional with Bluetooth included. There is one problem, the bluetooth is passive in the 2din radio. It means that does not show any pop-up window for pairing code. It can see the bluetooth of ecu, but can not pair.
Is there any way to upgrade your app for passive bluetooth receiver?
Thank you for your support. I'm looking forward your reply.
Best regards
M
Re: bluetooth problem
Post by Jadzwin » Thu Jun 18, 2015 1:54 pm
We will check what we can do.
mmt
Post by mmt » Thu Jun 18, 2015 2:12 pm
Jadzwin wrote:Hi!
ok
THX
Mobilelpg
Post by Mobilelpg » Thu Jun 18, 2015 3:23 pm
Would it also be possible to add into the app so it shows which Table set you are running on?
I have a current issue where my ECU keeps flicking between table sets and it would be good to see when it is happening on the app.
Edward.
mmt
Post by mmt » Mon Nov 16, 2015 9:15 pm
hi
I'm still waiting
I wrote an email to Artur and Jakub
Arthur wrote it forwarded Jakub
  but again a month away nothing
it's been so long that the radio can not return back :oops:
I can help me, or should I sell radio
br
M
Post by Jadzwin » Tue Nov 17, 2015 6:22 pm
Hi MMT!
We've checked this and unfortunatelly there is no possibility to make it run :(
mmt
Post by mmt » Sun Nov 22, 2015 11:33 pm
would it be possible to upgrade your Ecumaster app for all 2din Android car stereos (for example Eonon: http://www.eonon.com/)? I'll pay for that if needed. All these car stereos have a passive bluetooth. It means they can connect only with active bluetooth devices like cellphones or tablet PCs. Your app works only with active bluetooth devices - cellphones or tablet PCs.
We tried several models of 2din Android car stereos (for BMW, M-Benz, VW/Audi and Opel all with Android 4.4.2/4.4.4). Still same problem. The car stereo can see the ECU in the Bluetooth setting, but once we push the pairing button, it ends in this step, can't see the confimation pop-up window like in cellphones/tablet PCs. It is the difference between passive and active devices. Is there any way to change the paring method between ECU and Android devices?
Other way of pairing the ECU and car stereo could be using of a USB cable. Is it possible?
Thank you for your reply.
ihiryu
Post by ihiryu » Mon Nov 23, 2015 7:40 pm
On XDA they talk about this radio all the time.
The problem with the radio is that the BT is actually not part of the android side of it, it's actually part of the MCU. SO there's nothing they can do software wise to fix this.
They have a different radio that works (they show on the ad that OBD2 BT works on it), so I'd assume that it would with EMU. For reference, it's made by Hui Fei/Pumpkin
I know on my Lexus (when I still had it), my radio that was also made by Eonon, would not work with my OBDII dongle.
Wuniek
Post by Wuniek » Sat Jan 30, 2016 11:19 pm
I'm currently looking for radio with android and possibility to connect it to EMU... i don't have 2din space so I'm looking for something that will fit 1DIN
i found two units that can menage this one is :
http://www.ebay.com/sch/Vehicle-Electro ... in&_sop=16
and other:
http://www.autopumpkin.com/car-dvd-play ... -wifi.html
taking to consideration that EMU already has Torque support : https://play.google.com/store/search?q=ecumaster&c=apps
i decided to look something with android rather than windows, and the question is anyone already has working something similar with EMU? if yes please post brand and model
regards
Adamw
Post by Adamw » Mon Feb 01, 2016 10:11 am
Another display option that might be worth investigating is gauge art: http://gaugeart.com/
Since EMU can now output AEM CAN data stream this device should work with EMU.
Gauge art converts the CAN data into video gauges that can be displayed on any LCD display that has VGA or composite input so doesnt matter if your radio is windows, android, linux, etc...
I have never used a gaugeart device so cant comment on how well they work but just stumbled across them on the net.
ihiryu
Post by ihiryu » Mon Feb 01, 2016 9:16 pm
That's new, I didn't know it could output AEM CAN data. Where is this at?
Adamw
Post by Adamw » Tue Feb 02, 2016 1:32 am
ihiryu wrote:That's new, I didn't know it could output AEM CAN data. Where is this at?
nolagg
Post by nolagg » Sat Feb 06, 2016 12:42 am
How does it get connected? All I see is a usb slot on the ecu?
Wuniek
Post by Wuniek » Sun Feb 07, 2016 6:10 pm
check this topic : viewtopic.php?f=19&t=82&p=402&hilit=port#p402
nolagg
Post by nolagg » Sun Feb 07, 2016 7:38 pm
check this topic :
Hey so since I'm already using the blue tooth adaptor, using the can gauges is a nono? Can your explain in a nut shell lol
clamp
Post by clamp » Mon Feb 08, 2016 12:57 pm
i have litle problem with bluetooth connection. sometime i need try more 20 times for successful connection . sometime from 1 try
I use Sony Xperia Z5 Premium but with my old Sony Xperia Z1 have same problem. Messeges is :emu is not found:
last night i recieve update for emu application? but what is new?
ihiryu
Post by ihiryu » Tue Feb 09, 2016 2:09 am
I noticed this happens when the screen goes to sleep on my old Galaxy S4.
WHen it does happen, I have to close the application, and turn BT off and on again before it'll connect.
clamp
Post by clamp » Sun Mar 20, 2016 2:50 pm
before two days i update my Sony with Android 6 and now i need try 30 min. for successful connection :( in my BT settings i see EMUBT but when start applications i see NO device :(
clamp
Post by clamp » Mon Mar 28, 2016 11:45 am
when ignition is on - engine off i don`t have problems ! bluetooth make successful connection from first time. When Engine is ON ... application can`t see EMU
FERNANDEZ
Post by FERNANDEZ » Sat Apr 30, 2016 9:47 pm
Any solution on this?
2JZGTE Powered BMW E39 540i (Daily driver) Build engine ECU Master EMU Flex Fuel FID1400 722.6 / NAG1 auto(5 speed) FSR cast manifold PT6466 272 cams
