1e trigger settings keep on changing on fresh ignition.
ESRA Car performance
Post by ESRA Car performance » Mon Feb 29, 2016 8:52 pm
as above.
when i put in say 6 tooth..trigger on 2e..
make permanent..
as soon as i trun off the ignition the settings go back to 2 tooth and trigger on 0.
what could be wrong?
Re: 1e trigger settings keep on changing on fresh ignition.
Post by Jadzwin » Tue Mar 01, 2016 1:20 am
As I know you are set up subaru 6 tooth trigger.
This trigger is for 4 cylinder subaru engines, and some parameters like num cylinders and num tooth are fixed and you cannot change it.
