I do not have problem with logging since I update to 1.061 exp 1 , now the laptop disconect after some time and I must unplug USB and plug it again , I think that it is connected with quick saves ( can they be turned off ) . It makes such problems on car power adapter and on 220v volt adapter in my garage . I check in log by the time of disconect there are no problems in all parameters
Several disconnection after update
Re: Several disconnection after update
Did you try without external powering of your laptop (using laptop battery only) ?
No
It is old laptop , can this 10 to 20 hrz sampling be the problem ...
Im not having any trouble. Try changing your usb cable
Today make 20 min log with other laptop on battery , have one disconnect right after hard 100% wot acceleration , unplug usb cable and plug it again then no problem ( without closing emu soft ) . Will see if there will be more problems tommorow
