Hello!
How to connect and configure the idle valve on the engine Toyota 2JZ-GTE?
idle valve 2JZ-GTE
Re: idle valve 2JZ-GTE
Please find attached wiring diagram.
- 1jZ,2jz stepper motor.pdf
- (67.35KiB)Downloaded 448 times
Close down the idle parameter view to the left in the picture and open it again then it should go active.
Ok, thanks!
Now outputs - "not assignet" and stepper not working...
Please check if there is idle control active 1 on the log or in idle log group window.
Your configuration seems to be ok. The fact that there is no assigned outputs in assigned outputs window is a bug (outputs are assigned for sure, bug is already fixed).
