Wasted spark
PBU
Wasted spark
Post by PBU » Sun Nov 02, 2014 10:08 am
Hi , is this correct for wasted spark ? 1 coil for cyl 1 and 4 on output1:G8 and the other coil for cyl 2 and 3 on output 2:G16 ?
Grts
Patrick
Maciekx
Re: Wasted spark
Post by Maciekx » Sun Nov 02, 2014 11:41 am
It's correct.
sablac
Re: Wasted spark
Post by sablac » Tue Feb 24, 2015 1:11 am
can i use 8 seperate coils for v8 engine or 4 with 2 exits - wasted spark
engine audi v8 4.2
thanks by
Re: Wasted spark
Post by PSI-Motor » Tue Feb 24, 2015 1:42 am
The emu can only drive one passive coil per output and one VAG active coil per output. I recommend Bosch or Ford coilpack. If there is 8 passive on the Audi i recommend installing external amplifiers. Hüco 13 8055.
Re: Wasted spark
Post by Jadzwin » Tue Feb 24, 2015 8:01 pm
You can connect passive coils in parallel.
Or in the case of the VAG coil, when you connect them parralel you need to add pullup about 1K between 12V and ignition output
sablac
Re: Wasted spark
Post by sablac » Wed Feb 25, 2015 1:16 am
it is okay if I use this original coils.that are currently on the motor - 3 pin conestor.
project will be turbo charged .do you recommend this or any other high performance ignition coils- wasted spark.
thanks by
Re: Wasted spark
Post by Jadzwin » Wed Feb 25, 2015 1:27 am
You can use these coils. Just connect them in parallel (2 to 1 output).
