Bugs and Feature reqests
astra vxr
Re: Bugs and Feature reqests
Post by astra vxr » Sat Dec 13, 2014 4:27 pm
Jadzwin wrote:This feature is already done. You just need EGT2CAN controller to connect more EGT probes.
Then you assign each probe to fuel injector and you can create correction map in function of EGT
thank you
nemitom
Post by nemitom » Fri Dec 19, 2014 12:58 am
Hello, I want to ask when is going to reworking gaudes?
It would be good to see at a glance the limits of a given quantity of options. As it has in EFI Tuner studio.
astra vxr
Post by astra vxr » Sun Dec 21, 2014 12:03 am
can you recomend one that you no that works also whats the best splitter as i will be useing bluetooth as well :)
astra vxr
Post by astra vxr » Sun Dec 21, 2014 9:40 pm
how about user defined gauges and ablity to remove stuff from the list on the left like remove flex fuel or vvt and only keep the stuff you use instead of haveing everthing there and renameing of desktops to what ever user puts
agree with nemitom tuner studio was /is a good program and very user friendly in the way you can configure it can show deg f or c boost in bar/psi kpa silly little things but makes it a good user program and auto tune
nemitom
Post by nemitom » Sun Dec 21, 2014 10:33 pm
Annoys me only gauge, otherwise seems to me ecu and sophisticated software.
Will the future there is one possible logging without a PC? (CAN module?)
Post by Jadzwin » Mon Dec 22, 2014 5:51 pm
Hi!
The idea to hide some unused options/gauges/log channels is very nice.
From the beginning of next year we will focus on windows client improvements to make it as easy to use as possible.
So we add your suggestions and some more cool tools.
astra vxr
Post by astra vxr » Tue Dec 23, 2014 12:30 am
+1 on data logger of some sort even if it made for this ecu i would pay to have one :)
something like a can addon that has sd card and button to start and stop logging would be spot on :D
Post by Jadzwin » Tue Dec 23, 2014 12:45 am
CAN is one of the option. The other possibility is Android device with BT (however the data freqency will be small 5-10Hz)
astra vxr
Post by astra vxr » Tue Dec 23, 2014 2:49 am
Jadzwin wrote:CAN is one of the option. The other possibility is Android device with BT (however the data freqency will be small 5-10Hz)
sound good what ever way its done :)
also maybe wrong section to post in but why is oil pressure is 15.9 bar and fuel 10 bar could we have them so we can scale them our self like useing one of these
http://www.ebay.com/itm/Pressure-Transd ... 2a482f7ef5 ( they do them in differnt sizes ) other wise we are limited to what sensors to use and why is oil 15bar ?
Post by Jadzwin » Tue Dec 23, 2014 2:55 am
You can calibrate any Oil pressure sensor and Fuel pressure sensor using Oil pressure cal i Fuel pressure cal. For pressures higher that allowable just enter the max values
If practice 15Bar and 8Bar fuel should be enough for everyone (however we want to extend fuel pressure range to 15 bar in the future)
astra vxr
Post by astra vxr » Tue Dec 23, 2014 2:59 am
Jadzwin wrote:You can calibrate any Oil pressure sensor and Fuel pressure sensor using Oil pressure cal i Fuel pressure cal. For pressures higher that allowable just enter the max values
brillient thanks yes 8 bar is enough for fuel :o most injectors lock out at 7/8 bar anyways
so i can use 150 psi sensor for fuel and just calabrate to suit :)
thanks again
nemitom
Post by nemitom » Tue Dec 23, 2014 2:03 pm
I thought to use as a logger Arduino (Atmel processor) and SD shield it would not be difficult ...
It would be possible to insert several the screens to BT software? For an idea of what it looks like ...
thanks
nemitom
Post by nemitom » Wed Dec 24, 2014 2:12 am
I would appreciate test outputs (ignition and injection)for example in the tools / test ignition and tools / test injectors in different modes (all, semi-sequence, full sequence) and adjustable frequencies either in Hz or RPM. Or will it come like a good idea?
PBU
Post by PBU » Thu Dec 25, 2014 4:32 pm
nemitom wrote:I would appreciate test outputs (ignition and injection)for example in the tools / test ignition and tools / test injectors in different modes (all, semi-sequence, full sequence) and adjustable frequencies either in Hz or RPM. Or will it come like a good idea?
+1 Would be good for calibrating injectors. For example give 1000 test pulses at 5msec PW. This way you can calculate flow and dead time. ;)
Kurt
Post by Kurt » Thu Dec 25, 2014 7:26 pm
+ another! I've been doing injector characterization using a JimStim, but I would really prefer a test setting with Inj PW and # of injections.
No Limits
Post by No Limits » Tue Dec 30, 2014 1:29 pm
The software crashes when I select them twice a output .
eg output 6 for IDLE, then when I select output 6 for speedometer comes a warning screen and the program crashes .
No Limits
Post by No Limits » Tue Dec 30, 2014 1:32 pm
Can you set the max. Output Freq. for Speedometer output from 1khz to 2khz. I need it for BMW e46 Speedometer
Post by Jadzwin » Tue Dec 30, 2014 3:25 pm
Hi!
Higher frequency for Speed output should be available soon.
What software version do you use and what is the exact reproduction of this crash ?
No Limits
Post by No Limits » Tue Dec 30, 2014 5:17 pm
Crash test
Set output 6 for Idle
Press F2
Set Output 6 for Speedometer
it comes a Warning
The outputs are not sets to any other eg Output 5
Post by Jadzwin » Tue Dec 30, 2014 6:44 pm
But is there application crash ? We cannot reproduce it.
Warnning is correct behaviour
