Unexpected missing tooth cause ?
lysyfm
Re: Unexpected missing tooth cause ?
Post by lysyfm » Thu Sep 08, 2016 7:40 am
New software helps. Everything works fine. Thanks!
j.g.
Post by j.g. » Wed Sep 21, 2016 11:22 am
I'm having the same probem (unexpected missing tooth) on my car and i have spend many hours to solve it without success...
Specificly, I changed the cable of my vr sensor to a full shielded 2x1 cable and the problem just 'moved' about 800-900 rpm higher(from 4900 to 5800).
I tryed to turn on pull up resistor as other members recomend, and the car shuts down and ecu resets then(seems logical to me).
My tps seems to be ok (no shortcutting).
I did the firmware update as you recomend and the random 'missings' dissapeared at low rpm, so it helped a little but seems to have another problem too.
Could that be a 'noisy' alternator or something else?
I attach my last log hopping someone can help :D
thanks in advance, John.
20160913_1936.emulog
(330.26KiB)Downloaded 54 times
Post by Jadzwin » Wed Sep 21, 2016 7:49 pm
In new firmware (1.174) there is an option for primary trigger to change VR sensitivity over user defined RPMs (VR sensitivity switch)
Try this option
j.g.
Post by j.g. » Thu Sep 22, 2016 11:34 am
I missed that :oops: :D
I'll try this today, sounds promissing :!:
j.g.
Post by j.g. » Fri Sep 23, 2016 10:48 pm
I tried this today, with no results... when I adjust the sensitivity to any lower rpm (than default),the problem occours at even lower rpm..I use 1,173 firmware &softare whitch has that option too.
Another thing I noticed, is that the laptop disconnects immediately, when the problem occcours, so I cant log it.
What else can cause that problem?
Should I update to 1,174 ? :?
20160923_2314.emulog
today's log
(722.85KiB)Downloaded 47 times
Post by Jadzwin » Sat Sep 24, 2016 11:43 pm
Sounds like grounding problem (if the laptop disconnect) or heavy noise.
Do you have osciloscope ? How are grounds connected in your car ?
WHPZach
Post by WHPZach » Sun Sep 25, 2016 12:52 am
j.g. wrote:I tried this today, with no results... when I adjust the sensitivity to any lower rpm (than default),the problem occours at even lower rpm..I use 1,173 firmware &softare whitch has that option too.
You could very well be having problems with your ignition system leaking high voltage. Are your wires/boots in good condition, no signs of arcing? Are you using resistor type spark plugs?
j.g.
Post by j.g. » Sun Sep 25, 2016 12:29 pm
Grounds are connected from ecu to cylinder head and from there to chassis. My multimiter shows '0' resistance from anywhere to ground pins of emu.I will check the oem grounds to be sure about them too.My coils are grounded to engine head(as the other grounds), but at a different spot.Should I relocate any of these?
If you take a carefull look at my first log you'll notice that exactly same thing happens to knock sensor chanel, when rpm rises, so I'll start by checking the alternator as it seems to have noise everywhere.
The alternator itself is a bosch 65A and if i remember weel, it has a noise filtering capacitor.I think that this can be the cause :idea: , correct me if I'm wrong.I also purchased a suppressor type capacitor at 2,2mf 230vac(don't know if I can find the same as the oem..), can i use that instead of the original, or connect it via B+ & ground keeping the other as it is?
Unfortunately i dont have an oscilloscope, so I will test/run it without the D+ cable connected, to see what happens and point the problem, before doing anything else.
As far as the plugs, they aren't resistor type. I'll swap them if my alternator isn't the fault.
Thanks for your advices I'll post any udate ;)
WHPZach
Post by WHPZach » Sun Sep 25, 2016 7:47 pm
j.g. wrote:Grounds are connected from ecu to cylinder head and from there to chassis. My multimiter shows '0' resistance from anywhere to ground pins of emu.I will check the oem grounds to be sure about them too.My coils are grounded to engine head(as the other grounds), but at a different spot.Should I relocate any of these?
Swap your plugs first.
j.g.
Post by j.g. » Thu Sep 29, 2016 6:36 pm
I swaped my plugs today with resistor type and there is a significant improvement, but still does the same thing after 6000 rpm.(first time i saw the shift light flashing :!: rev limiter is set at 6400 and the control range at 100rpm, unfortunately i can't reach it, but we're close)
I didn't have time to log it, but i noticed that the 'check engine' light isn't powered after 5k. Before it was always on after that rpm, indicating knock, so now its definately better. ;)
I'll try to reduce the dwell time a little , see what happens and test the vr sensitivity option again.
I'm using 9125601 volvo cois and the dwell times are the lowest(6A) from the table I'm attaching.I found that table online, can anyone confirm those settings?
Does these coils need a suppressor on their power supply :?:
Post by Jadzwin » Thu Sep 29, 2016 11:06 pm
The numbers look resonable.
Please post the log here we will be able to help you for sure.
j.g.
Post by j.g. » Fri Sep 30, 2016 6:20 pm
I don't have a log with the new plugs, I'll post it as soon as I can, (probably on Sunday or tomorow if possible), but I i haven't change anything since the last posted one.
Thanks a lot :D
j.g.
Post by j.g. » Mon Oct 03, 2016 2:44 pm
Today I finally had some time to log it. The disconnection problem seems to be solved with the new plugs.
The unexped missing tooth issue appears at 10:30 and 13:10 on the log.
I tested to disconnect the altenator (d+ cable off) and same thing happened (didn' logged that...), so I think thats not the cause of this situation.
20161003_1214.emulog
(560.95KiB)Downloaded 42 times
Post by Jadzwin » Mon Oct 03, 2016 10:20 pm
Try 10K resistor in series with primary trigger input. And please put here your calibration
Paulo11
Post by Paulo11 » Mon Oct 31, 2016 11:24 am
Hi guys, I have some "Missing tooth" problems. Looks random and i have no idea what causes it. Everything it´s new(senzors and harness too). Here is my log and scopes.
20161028_1953_fiat126_trig.error_ignition.emulog
(1.9MiB)Downloaded 37 times
scope_20161028_1958_fiat126_trig.error_yes.emuscp
(281Bytes)Downloaded 38 times
scope_20161028_1957_fiat126_trig.error_no.emuscp
(453Bytes)Downloaded 40 times
Paulo11
Post by Paulo11 » Tue Nov 08, 2016 7:27 pm
Problem solved- new hall senzor wasn´t good.
j.g.
Post by j.g. » Fri Nov 18, 2016 3:06 pm
Jadzwin wrote:Try 10K resistor in series with primary trigger input. And please put here your calibration
The resistor solved the problem :D .Thanks a lot for your advices!
When u have some time please take a look at my calibration and log to help me about dwell times, just for being sure about them too.
20161117_1959.emulog
(1.82MiB)Downloaded 43 times
1711.emu
(101.23KiB)Downloaded 48 times
